So you mean to tell me, that a mad scientist such as yourself is going to simply use factory mounts and chains?
Surely you can come up with something way cooler than that.
A plate will be too hard to integrate. And I agree w/ you the chain is an embarrasment.Late to the party here.... I vote motor plate. You will be making far over 80 HP and stockers are not! up to the task. You will regret the use of stock mounts.... Chains are ghetto and this isn't a "hood" build. If anything use a solid chromoly rod type limiter like the one I have from racecraft.
OWWWWWW!!What about using the factory mounts and using a midplate to limit the rotational force trying to utterly inialate the motor mounts.
When you get your video feeds up and running include footage of you posting on stangnet as I can only imagine how animated you are when you're typing this stuff up!
I can reply to you at the same time to shut the hell up.If it's a live feed, we can all text you with words of motivation like, "You're doing it WRONG".
I'm nothing like anybody imagines. Much to their dissapointment.
see, that's what the place is coming to.
Ask how much Hp, what color I should paint my car, or what tires/wheels I should chose, and there'd be 29 replies.
Ask a question that even hints of " other than bolted on", and you get crickets.
So...........it has a turbo, boosted cars, especially street driven boosted cars typically do not have lots of overlap. It is the overlap that causes the shake, shake, shake of the engine.dude, the thing has a solid roller cam in it.
all I know is cam is ground on a 114 lsSo...........it has a turbo, boosted cars, especially street driven boosted cars typically do not have lots of overlap. It is the overlap that causes the shake, shake, shake of the engine.
The 114LSA is the overlap, 114 is very typical of stock type camshafts. With the duration @ .050 being 236 *, 224* any "poppity pop" will be the most noticeable when the engine is cold. Once it gets fully warmed up, it may have just a hint of a lope at idle, but nothing that is going to rattle the dash or windows.
