Stock Pulleys?
No, they will not work.
The 94-95's have a diff. timing cover/water pump setup that moves them closer to the block and this also makes the alt. and other acc. closer. The crank pully is preaty much flush with the harm. ball. The fox stuff is preaty far off the harm. ball. and such as they have the acc. and pumps much closer to the rad. (my guess for fans.)
TheDamned said:
just get some new ones off ebay or someshing, i got a some MAC ones slightly used for 110$ CND
I already have underdrive ones. I'm trying to get a stock set again to use on the street. If I use the underdrive ones the alternator isn't putting out enough to power my electrical right on idle. I guess a couple thousand watts and a couple batteries put a strain or something :D
ohhh my bad, tough you were talking about the u\d :nonono:
