Stock Rocker Arms
Are you 100% positive? I am trying to order some AFR heads, but I have a lot of different people giving me a lot of different answers.
If you are 100% positive that you have a genuine Cobra 5.0, than I am 100% positive that the factory Cobra 5.0 motors from 1993-1995 had Pedestal mount, 1.7 ratio roller rocker arms. They were made by Crane for Ford and had both Crane Cams and Ford stamped on the rockers.
Crane still makes these rocker arms, part # 44746-16.
If you have the stock rockers, and want to reuse them, get pedestal mount heads.
A L L OEM Iron Ford heads are peds unless somebody modified them :)
This holds true no matter the ratio
and
No matter if GT or Cobra
Grady
ALL OEM Ford heads?
OEM Ford 289 heads were available as press-in stud or screw-in stud mount.
OEM Ford early 302 heads were press-in stud.
Some OEM Ford Big Block motors were shaft mount.
Just a few examples of OEM ford heads that weren't pedestal mount.
ALL OEM Ford heads?
Well ... You got me :rlaugh:
BUT
Since this is a forum for 94-95 push rod motors ;)
Your info is right on my friend :D
Grady
