Stock Tach Not Working...
KDK1988GT
1,937
Fredericton
Last winter I picked up a brand new painless wiring harness for my car, It has a wire for a tach hook up and when I've hooked this wire up to three locations that I figured would be the correct spot to hook it to. When I do this the car will not start it just cranks over and over..
- I've tapped this wire to my MSD tach out and no luck car will just crank over but nothing else.
- to my coil + side same results
- to my coil - side same results
I have my monster tach hooked to my MSD box and it works fine, but I would like to get the stock tach working again so when I data log I can log my RPM.
Any thoughts on this? Thanks!
The stock tach connects to the IDM circuit on the computer, computer wiring connector pin #4, dark green/yellow wire. There is a 22K resistor in the circuit and the tach connects to the computer side of the wiring and not the TFI module side.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
