Engine Stock TB - smoke test - leaking bad
  • Thread starter Thread starter R82148V
  • Start date Start date May 18, 2025
First Prev 2 of 2
J
Jarhead67
5 Year Member
Nov 24, 2018
172
64
38
Windsor Locks, Connecticut
May 24, 2025
#21
  • May 24, 2025
  • #21
R82148V said:
Hey everyone,
I have a strange idle issue. when the engine is warmed up it idles good but as soon as you tap the gas or stop at a red light, idle goes up to about 1200 and slowing comes back down under 1000. It’ll usually hunt a little then finally calm down. Did a smoke test and found three areas of a lot of smoke leaking. Egr valve out the vent holes, out the tps and i even have a tps without a hole and the last leak is under the TB at the spring shaft. all three locations was releasing a ton of smoke. TB is stock from 1987. Is this TB toast? would I be able to rebuild the seals or better to just upgrade? I read that they all leak a little but there was a ton of smoke coming out .
Time to replace the throttle body, EGR, and TPS. Now might be a good time to remove EGR and put an EGR delete plate on it.
J
Jarhead67
5 Year Member
Nov 24, 2018
172
64
38
May 24, 2025
#22
  • May 24, 2025
  • #22
R82148V said:
Hey everyone,
LMR has Accufab, BBK, and SVE throttle bodies. SVE are a little cheaper.
Have you checked CJPony or BLUEOVAL?
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
May 24, 2025
#23
  • May 24, 2025
  • #23
Did you read the whole thread?
Fixes are already in motion.
R82148V
256
59
38
May 30, 2025
#24
  • May 30, 2025
  • #24
Update -
Just received the Accufab 65mm TB and matching EGR. Working on port matching the intake to match the EGR spacer and installing all the other parts to it. This thing is beautiful! Updates to follow
Reactions: Noobz347 and gkomo
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
May 30, 2025
#25
  • May 30, 2025
  • #25
R82148V said:
Update -
I've suggested to Accufab before that they need to make throttle body Christmas tree ornaments.
Reactions: R82148V
R82148V
256
59
38
Jun 4, 2025
#26
  • Jun 4, 2025
  • #26
R82148V said:
Update -
Update -
LOOKS AND FEEL
TB and EGR spacer has been installed. Looks great! I noticed the throttle blade doesn't have that small hole the way the stock one does.
It runs so so much better, cleaner and much more throttle responsive. Also, with the stock TB at highway speeds, 4th gear going into higher RPMS, you could feel almost like a drop off in pull once you reached 4000ish. Like it was running out of breath or something. With this 65mm Accufab, that feeling is gone! At 4k rpm in 4th, it just wanted to keep pulling !!
IDLE
I did the idle reset but only how accufab instructed me to. To get the TPS at .98 v and never touch the throttle plate screw. I did this on a cold engine though.
Idle seems better than it was with the RPMS dropping quickly to idle. Hunting is almost gone but still a little there.? No where as bad as before.
Could this be because I did the base idle adj at cold or is the PCM still learning?
I never did the full base idle adjustment that we all know about as in un plug the spout, and IAC, do adj with engine off then disconnect the batt and run it for 2 min with no accessories on then 2 mins with on? would this sort of this be best?
General karthief
Mod Dude
Aug 25, 2016
28,117
10,735
213
polk county florida
Jun 4, 2025
#27
  • Jun 4, 2025
  • #27
Try the computer reset,
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Jun 4, 2025
#28
  • Jun 4, 2025
  • #28
You cannot properly set idle with the spout connector in. The EEC tries to makeup for your screw adjustments with timing.
Reactions: General karthief
R82148V
256
59
38
Jun 5, 2025
#29
  • Jun 5, 2025
  • #29
I'll do the base idle reset again but the full version with the spout conn out. I'll report back !!
Thank you!
Reactions: General karthief and Mcmahst
First Prev 2 of 2
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
