I have notice in the last couple of days my car surges at stoplights, does anybody have any idea what is causing this?
sgramer said:How long have you had the plenum, K&N, and the cold air kit. You may need to clean your MAF, because of the K&N oil. You may need to reset the computer because, of the plenum. Do you have a bend in front of the MAF, because of the CAI, if so you may need to change that.
Scott![]()
jrc_03_gt said:do you have underdrive pulleys?
SRMobile said:Idle Air Control... Apparently its a comon problem on the stangs and usualy needs cleaning replacing after a good amount of millage.
Symptoms include stalling and having to give a little gas in order to keep the engine going while idling.
big o car 4.6 said:and what would that have to do with it
But did you idle surge a lot?SRMobile said:Under drive pulleys do exacly as the name states. It underdrives the accesories on the engine in order to free up some power. I did this with my last car and when at a stop light, my lights would dim, AC would slow down and the idle would be quite low.
