96SVTpilot
Why not just get some good zinc washed rotors and be done with it. I've had some on for a year of DD and not a speck of rust anywhere. None on the edges, wheel mounting face, nothing.
Modular2V- WTF?? the oil soaks into the pad material and even if dried, WILL come out when the brakes get hot, causing your pads to not grip very well..why do you think a new set of pads will be JUNK if you spill brake fluid on them...brake fluid does the same thing as oil to pads, soaks in and comes out when you need your brakes the most...just a bad idea, wrecking a 4,000 dollar car over some junk 50.00 brakes is just dumb IMO
~Mark~
This is all an awful lot of work, when he could just take off the tires and backing plates and rattlecan spraypaint the whole thing... maybe 8 bucks and 2 minutes a corner?
Just get the rotors turned in the spring
I know it's a lot of work.
I wouldn't even go that far. Like i said before...my car's been stored 2 years and the rotors are still fine...although lightly rusted over.
