Ah, yes I had the same problem, but you are in luck. The install is very easy, and should take you about 30 minutes if you work slowly and carefully. Pictures help a lot, the one included will allow you to see where everything goes, my recommendation is to assemble all the pieces outside of the car, then put them in the car. It helps you to make sure everything is fitting well. Make sure you do the air filter/metal box assembly, for some reason I found that to be the most annoying, esp. fitting it in the car (you may have to move some wires around a little). No big issues though, just take your time and if it looks like two pieces fit together, they probably do.
