strange camshaft timing....
  • Thread starter Thread starter forged302
  • Start date Start date Sep 13, 2008
F
forged302
10
Calgary
Sep 13, 2008
  • Sep 13, 2008
hey, here's the scoop everyone...... installed a new camshaft from crane cams (grind # HR-236/359-15) with the firing order of 1-5-4-2-6-3-7-8, when clearly thats not the standard firing order for a 1990 302 HO. Figured i could just fix the firing order on the distributor , tried that and it doens't fire up.
Before i changed the firing order to that of crane cams', the engine was running with the new cam and stock firing order; but not properly (which led me to checking the firing order on the new cam spec card)
FYI...... new 1.60 ratio rocker arms were put in along with many other goodies..
Any help is appreciated!
Maybe pull the cam for a different one:S maybe stock computer can't recognize this change in firing order..???
Bullitt347
I have been doing it wrong this whole time
4,061
3,133
204
Middle of Maine
Sep 13, 2008
  • Sep 13, 2008
The stock ECU is firing the fuel injectors at the 13726548 firing order and the distributor is firing the plugs with the 15426378 firing order, let alone the cam is opening the valves to the ignition firing order, thus, a no start will result, although there are 4 cylinders that are right, and it may try to run on 4 cyl, but not likely. Cyls # 1,2,6 and 8 are at the same time with both camshafts. Time to swap cams, or get a custom chip, if that is something that came be changed with a chip. Not a OBD11 ECU so no flash tuning can be done.
P
phutch11
328
Sep 14, 2008
  • Sep 14, 2008
Easiest solution is to make some wire jumpers that would allow you to "re-wire" the injectors.
Posted via Mobile Device
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 14, 2008
  • Sep 14, 2008
Not a good idea - it upsets the adaptive learning process for the computer. You end up with some cylinders running lean and others running rich. When the computer tries to adjust the air/fuel mixture, the injector it sees is not the one it adjusts. See Ford Fuel Injection Injector Firing Order for more information.
joel5.0
429
Puerto Rico
Sep 14, 2008
  • Sep 14, 2008
Such a condition is not a possible cause for a no start. If it was, truck V8 engines would never start (4 injectors are pulsed at once).... the system is simply using a FI waste pattern. A/F contol will be affected though, as Jrichker explained, but the engine should start and run. Should revisit the distributor firing order for the correct #1 post position on the cap..... if you want to confirm the cam's firing order, follow the paper plug procedure explained here.
F
forged302
10
Calgary
Sep 14, 2008
  • Sep 14, 2008
ok, so i have a few options it seems, i know that with a twin turbo setup come winter i will need a new computer anyhow, and i can acquire a megasquirt 2 and get the ford adaptor, would this be a plausible option for now to install the megasquirt 2 and change the firing order with that.?/?
This cam is insane, and i'd really love to keep it!
And the other option is put a different cam in with the correct firing order...
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
A
1991 5.0 - fires up every time, idles perfectly, but once it’s warm it won’t idle for more than 15 seconds
  • AmericanMuscle4.6GT
  • Jul 27, 2021
  • 2 3
9K
Fox 5.0 Mustang Tech May 21, 2022
Mindseye007
