Strange engine noise
  • Thread starter Thread starter tuhockey11
  • Start date Start date Jan 11, 2008
T
tuhockey11
81
PA
Jan 11, 2008
  • Jan 11, 2008
Need some help, cant figure this one out. Its not a tick, tap, or knock. More like a very slight thud. Can only hear it at idle and it does go with the rpms. Cant hear it at anything past 1200 or so rpm because its so quiet. I have an aftermarket oil pressure gauge and it shows fine. Car also idles and runs fine, just as before. I used the old screwdriver to the ear trick and it yielded nothing substantial. Could hear it a bit through the driver side rocker cover, but hardly anything at all. If anyone has any ideas, Id love to hear them.
fastford91
254
Niagara ,Ontario, Canada
Jan 11, 2008
  • Jan 11, 2008
take screwdriver out of ear now ?
R
rlntlss
9
  • Jan 11, 2008
sure you don't have anything wrapped around the drive shaft it could be sliding and catching ever so often
T
tuhockey11
81
PA
Jan 11, 2008
  • Jan 11, 2008
I checked around the driveshaft and exhaust, but everything looks fine. Its definately coming from the front of the car. I also checked to make sure the fan wasnt hitting the shroud, Ive had that happen before. Im hoping to take another look tomorrow, but I dont even know where else to look.
C
clayschmuck
48
San Antonio
Jan 11, 2008
  • Jan 11, 2008
Do you still have the original Ford rubber motormounts??? That would thud!
Clay
C
clayschmuck
48
San Antonio
Jan 11, 2008
  • Jan 11, 2008
Let me add a bit more to that....if they are worn out, they will thud! Sheesh...long day...
Clay
fastford91
254
Jan 11, 2008
  • Jan 11, 2008
i still say its the screw driver in your ear!!
C
clayschmuck
48
San Antonio
Jan 11, 2008
  • Jan 11, 2008
BTW, I'm still chuckling over your reply!
fastford91
254
Jan 11, 2008
  • Jan 11, 2008
dam took long enough to seance the humour in that!!! GEEEZZ
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
West Coast Best Coast
Jan 11, 2008
#10
  • Jan 11, 2008
  • #10
Mine does that too, when it's cold. Very faint.
T
tuhockey11
81
PA
Jan 11, 2008
#11
  • Jan 11, 2008
  • #11
Screw driver removed....thats better, no more noise The mounts do seem to be original and they are very worn, can that really cause a noise when idling though?
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Jan 11, 2008
#12
  • Jan 11, 2008
  • #12
Not likely. I think it is something to do with the rotating assembly.
T
tuhockey11
81
PA
Jan 13, 2008
#13
  • Jan 13, 2008
  • #13
I finally started the car after letting it sit for a couple of days and the noise is not there at all when cold. Only started after about a 10 minute drive. Is there anything that can cause a noise when warm only? Tried to look into it a bit more and cant get a noise from anywhere specific when using a hose or piece of metal to me ear. Sounds like drivers side of the engine bay, what else could it be? I assume if it was engine related I would hear something when listening to the valve cover, oil pan, etc...
T
tuhockey11
81
PA
Jan 13, 2008
#14
  • Jan 13, 2008
  • #14
Could a bad harmonic balancer cause a noise like this? Asking because while under there today I did notice most of the rubber hanging out the back(ordered a new one today) and after doing a search on another Mustang site a guy hada similar noise he couldnt track down and it went away after replacing the balancer. If anyone has an opinion on this, Id love to hear it
C
clayschmuck
48
San Antonio
Jan 15, 2008
#15
  • Jan 15, 2008
  • #15
I would still check your motor mounts....a long time ago, in a galaxy far, far away, I had stock motor mounts. I noticed this peculiar thud...occasionally and at weird times. Anyway, I used a pry bar to see if there was any play in the mount. I know it's just a suggestion but I hate to see people get stuck with a problem like this...
T
tuhockey11
81
PA
Jan 15, 2008
#16
  • Jan 15, 2008
  • #16
I checked the mounts abotu a month ago ad they were shot. I guess Ill go ahead a replace them anyways, along with the balancer and see if that clears it up. It really is a strange noise.....
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
