  • 1994 - 1995 Specific Tech
Strange Noise under mild acceleration
  • Thread starter Thread starter jims2321
  • Start date Start date Jan 28, 2004
J
jims2321
93
Oviedo, FL
Jan 28, 2004
  • Jan 28, 2004
Okay, I got a really annoying noise that started a few months ago, but I am finally out of ideas on the cause.
Here is the info. Under mild acceleration/deceleration around 1800-2200 rpm in any forward gear (1-5), I hear what sounds like a loose air vent flap noise. If I accelerate slightly faster, or go above 2200, below 1800 the noise disappears. I don't hear it when it is out of gear, and rev it upto the problem range. Any ideas?
Jim
J
jims2321
93
Oviedo, FL
Jan 28, 2004
  • Jan 28, 2004
Probable Cause Found ?!!?!!?
Okay, after reading over a dozen threads here and on other 'stang forums, it has become readily apparent that the clutch cable is the culprit of the 'play card in the spokes' noise, that I am hearing under mild acceleration, and it is across the rpm band, despite what I thought earlier. Also when the car is cold I get a howling noise (not loud, but I can hear it) when I depress the clutch. When I am off the clutch or a the bottom the noise disappears.
From what I have read, it looks like it time to rebuild the clutch, replace the throwout bearings, pilot bearings, seals, clutch plate, and assort parts, basically rebuild the entire thing. One major concern is the problem that so many of the forum members have had with clatter from the rebuild trans. Most seem to be due to the throwout bearing quickly being eaten up. So when the bearing is replace, shouldn't the sleeve also be replaced?
Before I am going to plop $500 - $600 down to fix the clutch (it is still driveable), I would appreciate any input.
Jim
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Jan 28, 2004
  • Jan 28, 2004
In addition to the clutch itself (disc, pressure plate, and throwout bearing), I would plan on replacing the pilot bearing, input shaft bearing retainer, pivot ball (for the clutch release arm), and perhaps even the release arm itself. And while you've got everything apart, you might consider doing the rear main seal (I wouldn't do it unless it's leaking, though, because you might cause it to start leaking where it wasn't before).
If you're doing the labor yourself, this can all be done for less than $250 in parts.
Dave
95GTvert[bv12]
1,792
Lake Tahoe, NV
Jan 28, 2004
  • Jan 28, 2004
i recomend a clutch upgrade...the stock clutch sucks and the car is a different animal with a new clutch....The Spec Stage II is a great clutch and will hold plenty of power
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
F
Resolved Stumble issue upon acceleration (1987 GT)
  • FoxDude87
  • Sep 16, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Dec 3, 2024
FastDriver
D
3.0L sounds like brush dragging from engine front
  • djim
  • Nov 16, 2021
  • The Welcome Wagon
The Welcome Wagon Nov 17, 2021
Mustang5L5
T
Engine 1989 Fox has hesitation (Stumbles) around 3K and under acceleration
  • tank76
  • Oct 21, 2022
2K
Fox 5.0 Mustang Tech Oct 30, 2022
tank76
T
Constant chirping noise from clutch/trans!!!
  • steezy2110
  • Nov 27, 2020
3K
SN95 4.6L Mustang Tech Mar 30, 2021
GT4Lyfe
G
