Hey,
Somebody help
I have a 93 cobra with some minor mods to the rear that include Ford Racing uppers, maximum motorsports lowers, Ford Racing springs, KYB AGX shocks, and 3.75 gears. I had the gears put in at a local shop and I did the suspension work myself about this time last year.
Everything was find until today, I started to hear a rubbing / whining sound coming from what sounds like the driver's side rear tire. It only happens when in neutral and turning to the right. It doesn't matter if its a hard 90 degree turn or slow 1 degree turn. The strange part, it does not happen when in gear...only in neutral when turning or curving to the right.
Any thoughts before I start painful process of elimination?
Axle? Differential? Wheel Bearing? Upper Control Arm?
Somebody help
I have a 93 cobra with some minor mods to the rear that include Ford Racing uppers, maximum motorsports lowers, Ford Racing springs, KYB AGX shocks, and 3.75 gears. I had the gears put in at a local shop and I did the suspension work myself about this time last year.Everything was find until today, I started to hear a rubbing / whining sound coming from what sounds like the driver's side rear tire. It only happens when in neutral and turning to the right. It doesn't matter if its a hard 90 degree turn or slow 1 degree turn. The strange part, it does not happen when in gear...only in neutral when turning or curving to the right.
I forgot to check the fluid while under there.
and it was on my list....BBAAAHHH
