Strange Rear End Problem
mikebrewer1
20
Myrtle Beach
Hey,
Somebody help :hail2: I have a 93 cobra with some minor mods to the rear that include Ford Racing uppers, maximum motorsports lowers, Ford Racing springs, KYB AGX shocks, and 3.75 gears. I had the gears put in at a local shop and I did the suspension work myself about this time last year.
Everything was find until today, I started to hear a rubbing / whining sound coming from what sounds like the driver's side rear tire. It only happens when in neutral and turning to the right. It doesn't matter if its a hard 90 degree turn or slow 1 degree turn. The strange part, it does not happen when in gear...only in neutral when turning or curving to the right.
Any thoughts before I start painful process of elimination?
Axle? Differential? Wheel Bearing? Upper Control Arm?
ok....I did some more research and lifted the car this afternoon. Sorry for the long winded post.....I'm about to take a sledge hammer to this thing.....
So far not seeing any visable scraps/scratches indicating rubbing on the chassis and around the suspension.
Did some banging around and checked the bushings and control arm bolts....nothing.
Pushed the wheels back and forth...no banging or clicking and the give seems fine.
U Joint looks ok.
Checked the downplay and movement of the driveshaft...its ok.
I came accross a couple of things that I'm not sure about. I had the wife hold 1 wheel while I rotated the opposite. I did this on both sides and it was easy to turn the opposite wheel, not much effort at all both ways...no clicking or banging.....should it be that easy?
Also, while all 4s are off the ground, I put it in gear and let the tire spin.....nothing unusual....no whine or grinding...would a axle bearing whine with no weight on the wheels? I also tried putting on the parking brake and easing out the clutch.....this produced a loud clicking on the passenger side ( opposite from where I think the orginial noise is coming from ). Do I need to adjust the parking brake? I haven't pulled the wheels off yet...going too tonight.
You are probably hearing the LSD engaging when you go throught the corner with no loads on the diferential...
If everything checks out under there, that is what my diagnosis would be.
According to the Ford Mustang Service Manual, it should take a minimum of 20 ft/lbs of torque to start one wheel turning while the other one is locked (breakaway torque). Less torque is require to keep that wheel turning once it starts. Anything less than 20 ft/lbs breakaway torque means a Trac-Lok rebuild is in order.
I know your test was more subjective, but this should give you some idea about the force required to turn the wheel.
Thanks for the posts. 20 ft/lbs sounds about right..didn't realize it would be that easy.
They are disc brakes in the rear.
Just spent the last 7 hrs making sure everthing is buttoned up. I checked the brakes and rotors and I do have a slight warp in the rotor on the passenger side ( thats where I'm getting the squeak and click sound from my earlier tests )
I'm still stumped....I dropped the whole rear and re-torqued everything. Re-hung the exhaust and checked clearance several times....jacked up the rear on both sides, compressed the shocks....everything seems ok. The only thing that concerns me about the suspension is that when I raise it from differential, the driver's side raises about 2" before the left starts to raise.....is that a problem?
Dropped it down, took it for a spin. Still there.....and again...only when turning right ( hard or soft turns ). It happens now in gear or coasting....but very loud when coasting.
If its the LSD, would it happen when turning in both directions?
ah yes.....:bang: :owned: I forgot to check the fluid while under there.:mad: and it was on my list....BBAAAHHH
I'll also put some friction modifier in there...any suggestions...how much? I have zippy experience with diffs other than what I've seen in other posts.
Yeah, friction modifier could be a good call. When I changed fluids I used Redline and it claimed to have FM already in it, but when I drove it around after the change I was getting the same noise you described, so I added FM and it was gone.
Just an FYI - the car needs to be sitting level when adding fluid, because you fill til it spills.
I checked the gear oil...it was a bit low...I put in 4 ounces of FM in and then topped it off.
Problem still there :notnice:
this car does not like to play nice......driving me crazy.
I think my next step is to get it on the road without the mufflers and tail pipes. Just to make absolutely sure its not the exhaust rubbing....:shrug:
If its not that.....its beyond me.....anyone want buy a 93 Cobra with only 35k miles on it but has a strange noise coming from the rear :mad:
