- Apr 26, 2004
- 373
- 0
- 0
My car sounds like it is shifting more times than it has gears. I'm driving it normally. Giving it more gas makes the car less likely, or eliminates, it doing this. WOT shifts are excellent, it's only partial throttle, or low RPM shifts that this happens.
I'm pretty sure the 4.10s are causing it, or that the car is doing it because of them. The car never did that before I got those in. I can't tell if the computer needs some tuning, or what exactly is going on.
More symptom details: it only seems to do this in the 2nd to 3rd gear shift. The car will make a noise like it shifted, but it didn't really. It'll hang onto the RPM's for about a second or two more, then it will finally shift to 3rd. It's almost like the transmission hesitates, or like it was going to shift there, or USED to shift there (such as when the stock gears where in) but hangs on a second and THEN shifts.
Also, 3rd to 4rth is not smooth.
Things I've done to sort of even it out, that haven't really worked:
1) Adjust the shift pressures/torque modulation with a Predator tuner
2) Change the transmission fluid
3) Drive it differently, just to see if any particular style suited the tranny more
I've seen someone else on here have similar problem, but they swapped to 3.73 gears and said it went away. I'm thinking the car just doesn't like the steep gears, but I want to keep them in. Any ideas on what I could adjust, or have done to the car to fix this issue? Things I should check, etc.
Things I've heard could be an issue are Torque Converter, and the computer needing a shift point adjustment, which I can't do with the Predator (without sending them the data, anyway).
Any ideas on this would be GREAT, as this has been something that's bugged me for a long time. I'm thinking of trying to find another stang just like mine that's a manual just so I can drive that instead.
Overdrive has a slight "lurch" when it engages, but that's about it.
