Strange transmission/drivetrain problem! help!
So I was cruising on the feeder road about 45 mph 3rd gear... tranny/clutch go out.
I lose all power and coast to a stop.
serious clunking noise start coming from car, NO NOISE in neutral with clutch PUSHED IN, however if clutch is let out (partially OR fully) in neutral, heavy loud clanking.
The car shifter will also slide into all gears, but has no "go" just more clanking when clutch is let out.
i put the car up on ramps, because earlier today there was a vibration coming from the car around 2,200 RPM, felt like driveshaft vibe... however, it seemed to get progressively worse throughout the day(the vibration) its a ford racing aluminum driveshaft btw. so i looked at the driveshaft, everything looks fine. the clanking was not coming from the driveshaft... but a foot or 2 away closer to the engine bay
Where should I start? whats wrong? rebuild tranny? not a mechanic, but knack for mechanics and would like to try work myself. This possible? bad idea? what parts to order?
All input/replies greatly appreciated ahead of time, thank you much!
-Brian
edit: specs of car 92 LX notch 5.0 302, S-trim only 5psi, 84,000 on motor, same on trans i assume, centerforce dual friction clutch(dont know how new, just got car), 30lb injectors, bbk throttlebody, cold air, yadda yadda, 3:73's w/ positrack rear end, ford racing aluminum driveshaft, pro 5.0 short throw
-Brian
