  • 1994 - 1995 Specific Tech
strange vibration
  • Thread starter Thread starter Tom95gt
  • Start date Start date Dec 29, 2007
Tom95gt
186
South Jersey
Dec 29, 2007
  • Dec 29, 2007
my car or should i say my engine has a tendency to vibrate from mid 3rd gear til i let off in 5th somewhere. shiftin from 3rd to 4th isnt bad but when i go from 4th to 5th i can really feel. its weird because sometimes the 4th to 5th vibration stop when i pull in the clutch but most of the time it keeps vibrating. my whole clutch is brand new i replaced everything i cud that had to do with it except for the steeda cable kit. it cant have anything to do with the clutch can it? i remember the vibration with the old clutch. not too sure where to start. my harmonic balancer i just put on about 6 months ago is a factory replacement and that made a huge difference but it seemed to come back so idk any help will be appreciated.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 29, 2007
  • Dec 29, 2007
Is it speed dependent, or happen at any speed, only when you're shifting into those gears? I'd take a look at the balancer again, just to be on the safe side, but it's probably a driveshaft issue. Too much slop in the u-joints, or if you installed it 180° out of phase from how it was originally installed could cause the vibration issue you're experiencing.
Tom95gt
186
South Jersey
Dec 31, 2007
  • Dec 31, 2007
its speed dependent. when i get up past i guess around 70mph
BlownFiveLiter
18
108
Chicagoland
Dec 31, 2007
  • Dec 31, 2007
Check your driveshaft for play in the u-joints and for proper balance, and also see about getting the tires checked for balance, too. I'm also pretty certain that the trans mount can cause some headaches, as well. Speed dependent vibrations are typically one of those issues.
fiveoho
1,958
TN
Jan 3, 2008
  • Jan 3, 2008
subscribing. i have a similar issue and have had it for a while. like mentioned above, the trans mount can play a big role in transferring lots of vibration. especially if it is a poly mount. also mentioned was the driveshaft, also a good point.
any experience with a aluminum ds from ford racing?
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
