Street Build - need engine help
  • Thread starter Thread starter sbarry5093
  • Start date Start date Jul 11, 2006
sbarry5093
  • Jul 11, 2006
I currently own a '93 GT that needs to be completely overhauled. In my high school and college days, I sunk every bit of extra cash I had into it until the last straw (the tranny) broke and its been sitting in my parents garage now for 3 years. Pretty much the whole car from drivetrain to suspension to paint to interior needs to be completely overhauled. From what I can remember it currently has just about every bolt on: cold air ind, mac shorties, H-pipe (no cats), dumped 2 chamber FM's, 70MM (i think) throttle body, larger mass air sensor (forget what size), GT40 intake, "F" cam, ported and polished stock heads, 3.73's. I would like to build what I would think would be the ultimate street stang capable of not only beating new vette's but also keeping up with new ferraris and porsches on a road course. The car will not be a daily driver but probably driven close to 10-20 miles a week, therefore I want to build something that will be as dependable as possible (don't want to be rebuilding each year) but also as wild as possible for that kind of use.
I'm looking for about 400-450 HP out of a N/A motor. My initial thought is to build a 347 stroker but I would one day in the future add a supercharger to get in the 500-600 HP range but I'm not sure how well the 347's take to that. If I go with that combination, from what I've read it seems the way to go is with CHP stroker kit and AFR heads? Would I need a 4 bolt main block though? Also, what cam would you suggest? Even if I stick with the 302 I do plan on building up the bottom end. Does anyone have any suggestions as to what would be the best combo there to achieve that HP level, friendly to a supercharger, but also be streetable for the kind of use I mentioned above with the 302 or 347?
Also, if anyone has any suspension suggestions, please post that too. I would like it to be a competition capable suspension but also streetable. I figure the front end needs a ton of work if not complete replacement. Also, with the HP numbers should i upgrade to a 9" rear end?
Thanks for any and all help
ninety15.0
1,336
  • Jul 11, 2006
um...you need to decide now if you want to stay NA or go FI. Compression ratio is going to be very important when you put this combo together. 400 -450 hp with a high compression NA 347 is pretty easy to do. On the other hand a low comp. FI 347 is pretty easy to get 500+hp out of. If you plan on 450+ hp you might as well get a nice block b/c you will split that stocker. For a motor like that a custom cam is your best bet. And i would plan on a pretty serious drivetrain (clutch, tranny, rear end, diff, axles.) Brakes and suspension would be next so a five lug swap is almost a must...full length SFC, upper and lower control arms, springs, struts, K member, c/c plates. Sounds like a good plan man...but i would guess you are gonna need about 15k to do it right and reliable.
LX93RiceKill
14
  • Jul 11, 2006
Those are high hopes for a N/A smallblock. Totally feasable, just plan it out right. You're looking at building a high compression engine, which isn't that great for the street, and isn't condusive to your future plans for forced induction. If it's going to be boosted later, build it for boost now, save you from having to replace the pistons again later. However, you did mention the roadcourse thing. In which case, many classes don't allow you to add a blower anyway. So I would make a game plan, get the rules for the class you want to compete in, and go from there. P.S.; on the roadcourse, you want HP, not too much TQ though. Think short stroke/big bore/high RPM power.
As far as the rearend, the 9" isn't really needed. A properly built 8.8 will hold more power than a smallblock can throw at it. Besides, the 9" acually costs you. Due to the pinion angle, it takes more power to spin it. If you're building a bigblock or turbo fed small block, for drag racing, then yes. Otherwise, no.
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Jul 11, 2006
  • Jul 11, 2006
Where are you located?
89stangWhiz
104
Mechanicsville, MD
Jul 12, 2006
  • Jul 12, 2006
I like this, it sounds a lot like what id like out of my car, the 'ultimate' street beast. Only right now its my daily driver, and upon completion mine would go back to a lot of driving or daily driver. But I would love to hear some ideas for a seriously well built mustang that could be a DD, and yet decimate all competition.
Can anyone chime in? I also dont want to be one of those on a budget type deals. What is your budget sbarry, do you have one in mind?
89white50
440
central MA
Jul 12, 2006
  • Jul 12, 2006
dart block = 1800
Forged rotating assembly (Probe 364 ci)=1200
nice aluminum heads all set to go= 1400
custom cam= 350
intake 450-600
You have a TB and injectors
TKO tranny =1400-1600
Aluminum d/s =240
rebuilt rear w/ new axles =400
upper and lower ctrl arms=350
Subframes and torque box reinforcements= 200+ welded in properly.
tune/chip= 500
im sure im forgetting plenty of stuff and have no idea what u really are going to need. im just showing you how much you will be EASILY spending
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Jul 12, 2006
  • Jul 12, 2006
89white50 said:
dart block = 1800
custom cam= 350
intake 450-600
Aluminum d/s =240
tune/chip= 500
Yep, it's just the proverbial "tip of the iceberg". Heck, I spent over $300 on new fasteners alone and that's not including any engine fasteners! Add up all of the hoses, belts, wires, doodads, and knicknacks and it's easily double what the big parts add up to be.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 12, 2006
  • Jul 12, 2006
The phase "road course" stands out: that is a very different engine from a 1/4 mile dragster. An engine built for road racing will generally develop less HP but have a broad torque curve and be able to turn up the revs down the back straight part of the course. You will be using high average power levels, but also need to be able to run the engine at those levels for an extended period of time. That means a different build from a drag racer engine.
That means you have some goals to meet:
1.) Reliable power that does not need a rebuild at the end of each season. Choose a 306 or 331 since they can run at high revs for an extended amount of time without excessive wear.
2.) Consider a intercooled supercharger and a low compression engine (8.5:1 - 9.0:1) to get the high peak power that will let you hang with the Vettes, Porsches and Ferraris on the back straight. Keep the boost level at 8-10 PSI and the engine will make good power and hold together longer. A Dart or World Products 4 bolt main block will be a must have.
3.) A custom grind cam to match the intake, heads and supercharger. AFR or Trick Flow heads, Trick flow intake, Procharger w/intercooler. Shaft type rockers are the best bet for an engine that turns high RPMs for long periods of time.
4.) Good cooling to keep the engine temps in line - radiator and oil cooler, along with an electric fan.
5.) The suspension for a road racer is going to take some effort. The Fox chassis isn't the greatest, but MM, Griggs & Steeda have some good packages. Buy a complete package from one vendor and don't mix a part here and a piece there. It's too much time & work to get it all sorted out and tuned. The suspension that works great for a drag car will not work well on a road race car - the dynamics are very different.
6.) Your 8.8 rear axle will be fine. Avoid using a heavier axle to keep down the unsprung weight. A heavier axle means stiffer shocks and springs to keep it in contact with the ground. Those stiffer shocks & springs play against the handling qualities and make it harder to tune the suspension and still be street drivable.
7.) Suitable trans –a Viper or Ford T56 6 speed is a must. A T5 isn’t even a consideration, especially in a road race car.
fidstang
307
South Lansing
Jul 12, 2006
  • Jul 12, 2006
89white50 said:
dart block = 1800
custom cam= 350
intake 450-600
Aluminum d/s =240
tune/chip= 500
I don't know what your budget is. If you can afford the list above, more power to ya.
But, if you're like the other 70% of us. We can't afford that at once. If you're can't afford that list in one swoop. Then you may want to think about a stock rebuild(306 of course)
maybe forged internals if budget allows
a good set of heads flowing no less then 220cfm on intake and 160cfm on exhaust good street intake
high flow fuel system
single or twin junk yard turbo build- you will be able to get 450whp+
*if not using new turbo(s) rebuild the used ones first. Very cheap and easy to do.
Wideband O2 sensor and gauge
Then most important part to a high horsepower build- TKO transmission
Like 89white50 stated above
Subframe connectors(full length)
Torque box reinforcements
Rebuilt rear with supporting hardware
New rear control arms
Lets not forget the D.R.'s tires are important to!
The above will still set you back 5000 -6000 dollars
Marbe you should look into a 351w swap and a TKO trans. You can easily get 400-450whp from this swap. Can be done cheap, even with a 351w rebuild to 392ci.
I'm looking into this route myself. Stock 351w block(stock bore), 3.85" crank, 91 HO stock pistons, stock 351w rods.
sbarry5093
#10
  • Jul 18, 2006
  • #10
Thanks for all the help guys...I'm not sure what I will end up doing. I want to go the stroker route and do it right, but there a budget in mind. By the time its all said an done, I don't want to put anymore than $20K into the whole project (thats everything), but just be really looking at how expensive its going to be build a stroker with all the right pieces it may not be possible to keep within that with everything else I want to do. Maybe I'll just keep the stock shortblock and go the heads, cam, intake, supercharger route. That should get me over the 400HP mark I would imagine.
As far as the suspension goes, I'm sorry if I implied I was going to be competing with it...I probably never will, atleast not with this car, but that is the style of suspension I would like to have. I just don't want it to be a full out drag setup where you can rest your elbow on the rear spoiler and the backend of the car sinks.
Thanks again for all the help
bob331T76
76
so cal
Jul 18, 2006
#11
  • Jul 18, 2006
  • #11
Dart 8.200 Deck New Block
Scat 4340 Steel 3.250 Stroke Crankshaft
Scat 4340 5.400 Connecting Rods
Probe Dish Top Pistons
Balanced To 28oz
Clevlite Rod & Main Bearings
AFR 205 Cylinder Heads
Cometic Head Gaskets
ARP Head Studs
Crane Hydraulic Roller Lifters (Link Bar Type)
Manley Chrome Moly Push Rods
Melling High Volume Oil Pump
Perfect Circle Plasma Moly Rings
Performance True Roller Chain Set
New Pioneer Timing Cover
Moroso Oil Pan & Pick Up
ARP Hardware Throughout Engine
Isky Hydraulic Roller Camshaft
Isky Hydraulic Roller Camshaft, Specs:
Lift Intake .539
Lift Exhaust .565
Duration Intake @ 50 225
Duration Exhaust @ 50 232
Lobe Center 114
Here you go copy paste give to your engine builder and Boost the ***** out of it like im doing:SNSign:
For your suspension just goto maxium motor sports and your set
Black1987Stang
1,422
Jersey Shore
Nov 11, 2006
#12
  • Nov 11, 2006
  • #12
I say build up a 302 and turbo it
savegoodautonfg
1,085
#13
  • Nov 11, 2006
  • #13
sbarry5093 said:
I currently own a '93 GT that needs to be completely overhauled. In my high school and college days, I sunk every bit of extra cash I had into it until the last straw.
THat part sounds just like me. im just starting college and im 18 years old. i have no money ever because of my car.
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
