Stripped stop bolts
  • Thread starter Thread starter jpctln
  • Start date Start date Sep 12, 2004
jpctln
198
StL, MO
Sep 12, 2004
  • Sep 12, 2004
I bought a used Pro 5.0 shifter a couple months ago. Well the previous owner adjusted the stop bolts to fit his T5...like he should...but it doesn't quite fit mine. The 2-4 bolt is fine, but the 1-3 bolt is a little too far out, and doesn't stop anything; it's useless. I didn't really worry about it too much when I first put it in, but now I'm getting ready to put in a new clutch, and I want to get this fixed just to be safe for when I chirp some gears. Anyway, the guy threadlocked the stop bolts with the strongest stuff out there, and I ended up stripping the bolt trying to get it loose with a 2ft breaker bar . I remember hearing the bolt was 1/2", and that was the smallest size I could get on the bolt, both metric and inches, but there was still a little play in the wrench. I took my chances and ended up ephing the bolt up.
How do you suggest I get that bolt out? Also, I'd probably need to get a new bolt and nut, so if anyone knows the dimensions of that sucker let me know, thanks.
jpctln
198
StL, MO
Sep 13, 2004
  • Sep 13, 2004
Bumperupalump.
HISSIN50
34
129
Sep 13, 2004
  • Sep 13, 2004
i might carefully heat the bolt up (breaks loose the threadlock somewhat) and then use whatever means (vicegrips, easy-out, etc) you see fit, to try to get the bolt out.
good luck.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 13, 2004
  • Sep 13, 2004
I'm not for sure threadlock was the brightest idea from the previous owner...I've never had a problem in the few shifters I have dealt with where the stop bolts move either direction...
Yeah try some heat...but be careful of your surrounding interior...if you don't you better have a fire extinguisher ready
I would think a 2 ft. breaker bar would break that thing loose...it must be on there really good...or was installed improperly...but if you can't get the right wrench on it that is the problem...
I say take it off and get a new shifter
jpctln
198
StL, MO
Sep 13, 2004
  • Sep 13, 2004
How much heat does it take to get to the center of a tootsie pop? Do I need a big ass torch or can I hold a lighter up to it for like 10 minutes?
old_blue
1,783
282
124
Sep 13, 2004
  • Sep 13, 2004
if it was red threadlocker then I blv it handles up to 400 degrees. So no, a lighter wont work. I would take it out of the car to work on it so you dont have to worry about ruining your interior or parts in the tranny heating up (carpet, tranny fluid, wires, etc...) and if that doesnt work then I agree with the above and just get a new one.
HISSIN50
34
129
Sep 13, 2004
  • Sep 13, 2004
in my above post i was assuming one would be removing the shifter prior to trying heat or any other methods. dont heat the shifter up in the car!
good luck.
blk92stangg
583
Hawaii
Sep 14, 2004
  • Sep 14, 2004
I also assume you loosened the lock nut, right? Just stating the obvious...sorry.
giddyup306
3,041
Sep 14, 2004
  • Sep 14, 2004
It depends on which thread sealer it is. Permatex makes 4 different types of red sealer. If it's the green ***** run (unless it's the stuff GM uses then that's the red stuff...only green)!
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
