All,
I am new to the group, but, since I am spending all the money, I figured I would share what I was about to do with you all. My White 95 Convertible is completely stock except for the 3.73 gears and a CAI that I put on it. I am leaking out the rear seal so bad that it smokes when I turn the car off.
Therefore, it was time to take the leap.
I am currently having built or installing or having installed the following:
347 Stroker being built by Steen Racing in VA Beach w/:
Forged Crankshaft, Pistons and Comp Cam Rods
Steen Racing Cam Shaft
Harland Sharp Rockers
Ford Racing Roller Lifters
Ford Racing Adjustable Double Roller Timing Chain
Canton Oil Pan
Melling High Volume Oil Pump
AFR 185 Heads/58cc chambers
Holley System Max Intake
Summit 75mm Throttle Body w/Trick Flow Adapter
Trick Flow Valve Covers
30# Injectors
30# MAF
Summit Underdrive Pulleys
Cold Air Intake
88ROTORS Drilled / Slotted Rotors with Raybestos Pads
KYB GR-2 Front Struts
KYB Gasajust Rear Shocks
Ford Racing 3.73 Differential
New RATECH Rear Bearings throughout
164 tooth Flywheel
Stage I clutch kit w/firewall extender
MSD TFI Coil
MSD Distributor
Granatelli Subframe Connectors
Yokohama Avid V4s 16” Tires / Stock Wheels (Good up to 149MPH)
SCT Chip
BBK Long Headers
BBK X-Pipe w/Cats
Flowmaster American Thunder Cat-Back Exhaust
Billet Fuel Pressure Regulator
Stock T-5 Transmission and Drive Shaft
Stock Radiator
Used ABS Unit (having to replace the stock one cause its toast)
Think I'll notice a difference????
I'll let yall know what the Dyno difference is after Ed Clark throws the SCT chip and tune on it.
Greg
Canton Oil Pan
30# Injectors
30# MAF
Cold Air Intake
164 tooth Flywheel
MSD TFI Coil
MSD Distributor
SCT Chip
BBK Long Headers
BBK X-Pipe w/Cats
Stock Radiator
Greg
