stroking an engine
when you stroke a motor, you use a crankshaft with a longer throw and depending on the combination different rods and pistons. the goal is to increase the distance the piston travels therefore giving a larger displacement. usually the rods and pistons are shorter. the only stroker motor i ever built was a 393W, used 351W block, custom crank, 351 rods and 302 pistons. when boring the block you make the cylinder wider. all you need to replace when boring the block is the pistons.
A well thought out stroker assembly should have a crank, rods and pistons all designed to work together in a well arranged fashion to ensure no oil consumption issues and overall longevity. Try to avoid strokers that use oil support rails. If you require a support rail in the oil control ring (due to wrist pin interference), chances are you may experience oiling issues. Not all do, but the chances are much greater.
