Strut tower brace help
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
I have the Steeda one, its chrome moly construction so really light weight. I felt it improved the front end rigidity especially felt when one side of the car hit a pothole it feels more buttoned down. Looks good under hood also.
I have the Steeda strut tower brace and this is my story:
(1) my car is an 02 GT
(2) it says to remove the plastic cowl at the base of the windshield, mine cracked when I took it off. I think I paid around $100 dollars for a new one from Ford.
(3) setting the brace on the strut towers the holes that were already there lined up ok.
(4) as I said before you need to remove the plastic cowl to mount the rear part of the brace.
After you trace around the rear mounting points take a Dremmel and cut out the plastic on the fire wall. There is no going back after that. The metal in the fire wall is very thin; and in hindsight I don't see how this can help, but at this piont it is what it is.
(5) drill the rest of the holes, this is pretty standard.
(6) now this is what happened to me (I don't know if this is common but this is my experience) the kit comes with 8 or 9 bolts to secure the brace to the car. I would start them easy by hand turn them another 6 or 7 good turns from the socket wrench then the bolts would snap. Now I know this sounds trivial but only getting 4 bolts out of 8 to snug up against the strut tower at 9 o'clock on a Sunday night kind of upset me a little and is not something you forget easy.
I know I have said some pretty harsh things about this company without backing them up but this is just my opinion based on my dealings with this company and their products. If I had the chance to do it over again I would not buy this brace.
I would buy the MM one because it mounts to the crease in the fire wall not the thin sheet metal.
Interesting point about the comparison. I just assumed they attached to the same exact points on the firewall and didn't notice anything being thin although it's hard to reach in there to tighten things down, so I didn't look for that point. I also notice from the links, the Steeda one is triangulated at the firewall points. Note the Steeda one has a slight bend to support a larger TB tube compared to the MM. The bend and the Chrome moly metal - didn't want to add weight there, were two of the reasons I went with Steeda. Not sure if the MM is Steel or Chrome moly?
Here's a pic of mine installed so you can see where it attaches to the firewall and the "upbend" in the CAI area.
With Stock intake
With densecharger TB tube
That looks like the MM one(where is mounts to the F/W) So yours allows for a larger intake tube?
Look on the LHS and compare it to the MM. The MM one goes straight across, where as this one does a little uptick to clear a larger TB tube. From the install guide on MM's site, it also looks to me that the MM one mounts to the firewall a little more outboard than the Steeda one. It might be thicker there?
I get what you are saying about the weight, but I don't think a couple of pounds will make that big of a difference in our already portly cars.
In the grand scheme of things it all adds up and I like where your head is. Colin Chapman would be proud (he founded Lotus).
I have the Kenny Brown one and love it :nice: Unfortunatly you cant get it anymore :(
The MM one mounts to the lip instead of the firewall. The bolts go through the lip on the firewall instead of through the firewall. That piece is twice as thick (since its two pieced welded together) and has more support :nice: The Steeda is a great second choice though. My 96 Cobra had the Ford factory one (also avaliable through FMPP) and it attached to the fire wall the same as the MM one so that says something to me if Ford decided that was the better way to do it.
I have removed the brace and played with the car through some corners and I could definatly feel the difference.
Also, think ahead and if you will be getting a positive displacement S/C cause that will debate which one you get too. Some will fit and some wont.
This was my 96 Cobra, you can see how the bolts go through the lip instead of the wall:
Now my Termi goes through the firewall and when I re installed it and attached thoes bolts the firewall flexed and I didnt like that but the bar helps and its a good piece :shrug:
