strut tower braces anyone?
I am having bad luck finding a brace that will clear my intake. It's and Edel. Performer 2 intake with an 1"1/2 intake spacer. If any of you have seen the Performer 2 intake it is rather large, (kinda like Trick Flow's older intake). Anyone have a brace with this combo or close to it? Maybe a little help finding a brace to even clear it. I can't take the spacer out otherwise it won't bolt down flush b/c it will hit the valve covers.
I don't know if the Maximum Motorsports strut tower brace will work with your intake. Here are a few pics of my GT. I still have the stock intake.
Hope this helps.
Keith
you have to get the open strut. i just bought smr strut tower brace and it wont fit over my edle either...but i am going with cobre intake anyway...but yeah you have to go with the open brace.
i hope this helps...or you can use other after market single cross brace and modify it a little and make it fit. you can just strong weld the eachend and it will work fine.
Duner, that one looks like it would work! I will have to see what their return policy is but I might give that one a try. If not I will just use one that goes straight across. Do any of you know the pros and cons of a brace that doesn't bolt to the firewall as well?
There's plenty of discussion on weather a STB is worthwhile. Go check out http://corner-carvers.com/forums/index.php? and do a search. Those guys are hardcore racers and engineers.
Here's link to get you started
http://corner-carvers.com/forums/showthread.php?t=448&highlight=strut+tower+brace
Another
http://corner-carvers.com/forums/search.php?searchid=548823
Some people swear they make a difference and others don’t. I installed the STB because I’m running coil-overs. Since the coil-overs put the entire load of the front suspension on the strut towers, it seemed like a good idea to install the brace.
If you are going to install the brace, get one that connects the towers to the firewall.
Maximum Motorsports are well known for their excellent parts and top-notch customer service. Give them a call. They may be able to answer the question about the intake clearance.
BTW don't register at corner carvers. Just read and search.
FOR THE FACT and not having to worry about it.. ford racings STB is built to clear the eddy and typhoon intakes.. its the only one known to work (or so says the seller)
