I have a set of adjustable Tokico Illuminas on the 88 (fairly new too). I was thinking seriously about putting them on the 97'. They should bolt up fine, and yes, they would have 1" less extension and 1" more compression. The ride height is stock. Anyone have a good reason I shouldn't do this? I would like to get something softer for drag racing on the 88, and these tokicos could really brighten the 97 I think.
Next question, is there is a big difference in springs between the 96-98 and the 99+s? My family owns several 99+s and they all feel like they're sprung slightly stiffer, espeically in the front. If I can bolt up some 99+ springs, and aleiviate the nose dive and poor handling of the soft 97 front end, I would be pretty happy. Is that a worth while swap?
Anyways, I wouldn't reccomend swapping a stock spring for another stock spring for any year mustang. The stock springs I had on my 2002 GT were very soft, and produced a lot of nose dive under braking also. If you are going to go through all of the trouble of changing out the springs, at least give your stang some good quality ones!! Plus, you'll like the results more!!
