Stuck again
  • Thread starter Thread starter oldfordguy
  • Start date Start date Sep 22, 2007
oldfordguy
11
Da windy city
Sep 22, 2007
  • Sep 22, 2007
Hey need some help. 71 Mach 1 351c with AOD. Kinda of limited shade tree guy here. Couple of weeks ago starter (ford motorsports hi-torque) stayed engaged. I tried a couple of times, all good, few times later again and it was not constant problem / checked for loose connections 3x, nothing. I also thought that I was having to turn the key further that I remembered to get it started. Then this week, after a fun run she cranked a bit , no start, but also there was a clicking sound. From inside could tell if it was from starter or solenoid. I replaced starter (w/OEM type) and new solenoid. The hi torque had a wire from firewall solenoid to unit on starter. I ground that to block since OEM has only POS hook up. Now when I try to hook up battery she cranks but without key ignition. I even tried taking I and S wires off solenoid and she still cranks with trying to hook battery cables. Do you think it is ignition switch or????
D
D.Hearne
11,730
south louisiana
Sep 22, 2007
  • Sep 22, 2007
it sounds to me like your battery is weak, all that usually happens with a near dead battery.
oldfordguy
11
Da windy city
Sep 22, 2007
  • Sep 22, 2007
D
You know I did have to replace battery when I put in new OEM starter. Soon as I hooked up POS cable, with no key in and ing switch in off position, she cranked and cranked and killed old one. I was thinking maybe it was drained along the way, or ready to go anyway. New battery, I can't even attempt to hook up both cables without it cranking , with key out and switch off.
Az Pete
711
18
49
Panama City, Fl.
Sep 22, 2007
  • Sep 22, 2007
Try removing the wire you just ground to the block, the one from the solenoid.
D
D.Hearne
11,730
south louisiana
Sep 22, 2007
  • Sep 22, 2007
Solenoid is stuck open. Hit it with a hammer. (gently but firmly tap on it, don't beat the hell out of it)
oldfordguy
11
Da windy city
Sep 22, 2007
  • Sep 22, 2007
Thanks guys!!! Classic "duh" moment. The old high torque starter had hot wire running to hot side of fender solenoid, OEM you have to run thru solenoid. So I just had to move starter hot wire to other side of solenoid. Back on the road!!
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
T
Electrical 1990 Vert starting/Solenoid issues
  • Tom77
  • Apr 18, 2025
Fox 5.0 Mustang Tech Apr 18, 2025
85GTStangGuy
