Drivetrain Stuck Clutch
  • Thread starter Thread starter mikesponycar
  • Start date Start date Jan 22, 2015
M
mikesponycar
  • Jan 22, 2015
I have a 289 with 4 speed that's been sitting for years. Now the clutch has welded itself to the flywheel. Once I get the engine started, how do I unstick the clutch? I've hear that several heat/cool cycles will do it, or start it in gear, or tow it with the clutch pedal depressed. Is there one way that's better?
horse sence
8,538
233
Wile Coyote's stunt double
Jan 22, 2015
  • Jan 22, 2015
I had a 428 with a stuck clutch disk .A 428 has a large inspection pan that exposes the whole bottom of the fly wheel ,the disk and the pressure plate .I had my brother push the clutch pedal while i gently pried the disk with a large screwdriver .The disk was a metallic disk and had rusted to the fly wheel .Very little rust actually but it was really stuck .A 289 will be a bit harder but you may be able to remove the starter and get at the disk with some type of hook tool.
M
mikesponycar
  • Jan 26, 2015
horse sence: Thanks for the reply and advice. Fortunately it unstuck itself after several heat/cool cycles. That's good to know about the starter access for the next time.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Engine Which fan clutch ?
  • AnthonyA1234
  • Jun 22, 2026
Fox 5.0 Mustang Tech Sep 19, 2026
Mustang5L5
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
