stuck door lock
  • Thread starter Thread starter skinnypGT
  • Start date Start date Aug 12, 2005
skinnypGT
211
Radcliff, KY
Aug 12, 2005
  • Aug 12, 2005
My actulator on my passenger door has frozen in the locked position
how do I get it to open up again
bubba-dough
1,044
Indiana
Aug 12, 2005
  • Aug 12, 2005
Take the plastic piece off the end that sticks through the door panel, get a heavy set of pliers, and pull as hard as you can (stay away from the threads or you will be going to a junkyard to get a new rod). It may help to try using the unlock at the same time. If it hasn't been froze to long it will come up.
When you get it up get the actuator out as soon as possible. This away you can still lock and unlock your car manually.
85mcLaren
45
  • Aug 12, 2005
That should work from above. I had one that pliers, etc. wouldn't work. I had to take off the door panel from the inside and undo it that way. A tight fit, but I did it... Didn't feel like letting my passegers act like luke duke and jump in through the window..
skinnypGT
211
Radcliff, KY
Aug 12, 2005
  • Aug 12, 2005
what exactly did you do from the inside ???
I heve the door pannel off and but can not get the door to unlock
it is hard to get to since the door is stuck shut
Euphoric306
905
  • Aug 13, 2005
yea i had to get my panel off from the inside and then we just took the actuator out and have had manual lock on that side ever since....
HISSIN50
34
129
Aug 13, 2005
  • Aug 13, 2005
For info's sake: on cars with a plastic actuator bracket, there is a rivet through the door (from the outside). On the inside (where the actuator is), the plastic bracket is held to the rivet with a snap ring. If one can get to the snap-ring (which sits conveniently behind the actuator), the actuator assembly comes free. Then one can snake the actuator's bent linkage out of the lock mechanism.
Doesnt sound like that will help, but since you probably cant see inside the door worth a hoot, it cant hurt.
Good luck.
skinnypGT
211
Radcliff, KY
Aug 13, 2005
  • Aug 13, 2005
Thanks for the help guys... yall pointed me in the righht direction finnaly got the actuator out of the car and the door open..
I must have spent 2 hours with it yesterday took me less than 20 min this mourinng ... like most things that stump me with cars it was painfully obvious once I fixed it...
A
ajaffer
28
  • Dec 14, 2005
I can get all the screws out but i cant pop out the door cover, howd u do it?
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
Electrical 5.0 88 Foxbody Door Locks
  • 88VertFox
  • Aug 29, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
Mustang5L5
