  • SN95 4.6L Mustang Tech
stuck gauges
  • Thread starter Thread starter Kraw
  • Start date Start date Jun 18, 2011
Kraw
Nail On The Head El Moderatoro
ATL via MSY via MLU via Pitkin, La
Jun 18, 2011
  • Jun 18, 2011
in my 01 GT, I have the temp and fuel gauge's not working. Sometimes, if I hit a bump, they may start to work again. With the fuel gauge, if it's above 1/2 tank, it'll show full; below 1/2 shows empty.
The temp gauge went about 2 years ago... no problem as I have a scangauge II. The fuel gauge quite maybe a year ago.
I took the gauge pod apart, hit the internals with compressed air etc but no joy. I've read on the older models, you can replace the stepper motor behind the gauge. It looks fairly straightforward, I just need to know if anyone else has done this and if so, where can I find them? I've searched, but can't find the ones like what I have (metal, not plastic)
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 18, 2011
  • Jun 18, 2011
Just so that I'm on the same game page, have you confirmed the grounds from the Cluster? There are two. Wire color black and BK/WH. Best to measure the resistance back to a known good ground (battery negative best). Should be low.
Have you access the cluster diagnostics? Any information? I'm interested in know what the logic "thinks" the sesnor input is. This will confirm if the problem is external or internal to the cluster.
Sure would be a shame to replace/repair the cluster only to end up with the same problem.
Has any work been done on the fuel tank? Any damage to the fuel tank sender?
Diagnostic Mode - Ford Mustang Forums
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
L
Fuel gauge and temp gauge
  • Logan1722
  • Jan 18, 2025
SN95 4.6L Mustang Tech Jan 19, 2025
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Autometer 3318 Fuel Gauge
  • cbac89
  • Apr 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2025
AeroCoupe
