Studder above 3,000 RPM when warm
  • Thread starter Thread starter LukeDorris
  • Start date Start date Sep 12, 2005
L
LukeDorris
  • Sep 12, 2005
i have an '88 5.0 GT. When I get on it, it begins to studder and cuts out very badly above 3,000 RPM. It only does this when its warm and under load. It always revs freely to the redline. Below 3000 RPM, it runs like it should, and it runs great when it is cold. Only after the car has been run for about 10 minutes. The car begins to blow smoke while cutting out. The problem happens everytime I run the car above 3000 when warm. I have changed the cap, rotor, plugs, pulg wires, ignition module, and ran fuel injector cleaner. I think the problem is an 02 sensor, the temperature sensor that is on my intake manifold, or a bad distributor. does anyone have any ideas?
P
Polter83
74
  • Sep 12, 2005
Pull codes?
List of mods, timing and fuel psi are at what?
What color smoke and from where? Any other sounds or wierd things?
L
LukeDorris
  • Sep 12, 2005
re: studder
it doesn't put out any codes according to my local shop, but they said something about taking it to a ford dealership to have all of the codes checked. I dont understand why he could check some codes but not all of them. The mods are just bolt ons, bbk shorty headers, mac off road h-pipe, turndown mufflers, march pulleys, FMX trans, stock timing, and i dont know what the fuel pressure PSI is, but would that be effected only after the car warms up? no other weird sounds other than when it cuts out. sounds almost like a miss.
stangnutlx
242
Coventry, RI
Sep 12, 2005
  • Sep 12, 2005
mine did it to me over the summer i replaced to 02 sensors and it fixed it
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Sep 12, 2005
  • Sep 12, 2005
Don't go off the deep end throwing parts at it.
Check the TPS readings form Closed to WOT, check for dead spots or spikes.
Another problem although not likley can be a weak coil. A weak fuel pump will cause this issue, it will maintain pressure, but will not be able to keep up with flow. Poor MAF output is another problem. O2 sensors should flux between rich to lean two to five times per second, ranges of .2-.8v's should be noticed.
Engine Misfire below 3K RPM
  • foxbodyclark
  • May 25, 2025
Fox 5.0 Mustang Tech May 31, 2025
General karthief
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
