Hi folks,
Mods are in my signature. I replaced my spark plugs with Autolite 3924s, 9mm Ford Racing spark plug wires, MSD distributor cap and rotor, and deleted the EGR. I had a local Mustang specialty shop double-check my work, and welded-off the EGR exhaust manifold bung. They also tried adjusting idle air, idle and verified TPS voltage of .98.
Now, the car stumbles and bogs-down under a load. It sounds/feels like mis-fire. A sputtering, machine gun feeling/sound. The exhaust sounds "flat" and not in "tune", if you can understand what I mean. Everything else seems to be functioning normally, with a very lopey, low idle ~900 RPM. Static fuel pressure is at 55 psi. MAF is calibrated for 24 lb. fuel injectors and the MAP sensor was installed with the A9L conversion long ago. The motor is determined to be mechanically sound. CEL has not illuminated. I've removed the SPOUT connector and drove it, and the stumbling, bog-down is minimized, but it still does not sound like it's in "tune". My narrowband Air/Fuel gauge shows a leaning during this sputtering. I figure the narrowband has some merit when showing lean and fat conditions, the extremes, with a light show bobbing back and forth as the computer tries to maintain stoichiometric ratio. When I modulate the throttle and back off, reducing the load, the stumbling and bog-down subsides and the narrowband AFR indicates fat.
Please give some additional guidance on things to check and verify.
Thank you,
Paul
Thank you,
Paul
