Stumbling Hard
68conv4sp
270
My '68 is getting better at producing some pretty respectable Autocross lap times, but is starved for gas as it exits a turn and stumbles badly at throttle application. Current carb is Edel 500 cfm that runs perfectly on the street. What carb do you guys recommend to solve the starvation problem?
Krash, I tried part throttle exiting a couple of hard turns, but it still acted like there was very little fuel. I'm not sure I understand your comment on the mechanical secondaries. Do you mean that when the secondaries open suddenly, there is insufficient fuel to mix at that moment? During hard straight line accel/decel there is no problem.
Yes. In greater detail what I'm saying is that when you floor it with mechanical secondaries, particularly from a standstill, you are opening up the intake to the atmosphere and you go from high vacuum to low vacuum very quickly resulting in the decrease of flow through the intake. I'm sure you've the sound of that brief hesitation before. Its the "Bu" part of "Bu-Whaa!"
You may have a float level problem.
How's the fuel filter?
Shelby used a center-pivot float Holley similar to the newer 4150 to minimize starving, flooding and fuel slosh. I'm not sure how to tweak the Edlebrock you now have to mimic this... :(
Also, have you changed your oil pan to one with baffles so you don't cavitate or lose your oil pressure? That would be a lot worse than just a hesitation caused by the carb. :o
Daniel
During the first autocross event a year ago, I finished w/ a ticking motor and also noticed that under hard cornereing the oil pressure went to near zero. I installed a high capacity baffled sump and that issue is cured. Someone else mentioned a "center pivot" float, but I know little about carbs and am not sure what that is. Sounds like I need to take a trip to the local speed shop.
I have never taken a carb apart. Is the float positioned so that if the fuel all sloshes to one side of the carb it is not available for use? I don't know how the fuel gets from the float/bowl to the venturis - gravity?
Crap, I haven't been inside of any but motorcycle carbs in a long time and they're significantly simpler. But yes, I believe side-hung floats can cause problems during hard cornering or if you were on a steep enough slope.
