Stumbling problem driving me nuts. please help
  • Thread starter Thread starter 1990MustangLX50
  • Start date Start date Oct 14, 2010
1990MustangLX50
89
  • Oct 14, 2010
I have this intermittant stumbling problem, only happens at wide open throttle off the line or after a hard shift into 2nd and sometimes 3rd. Ive checked my fuel pressure it is at 30 PSI with vac connected to regulator and goes to right under 40 disconnected. My engine is stock except for headers. I have replaced the throttle position sensor. The EGR valve opens when I apply vac to it. Other thing I notice is that when it happens i get a drop in voltage on the guage. I have a 3G alt upgrade from PA performance. When I drive normal I have no issues at all. Any ideas?
thanks in advance
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 14, 2010
  • Oct 14, 2010
You may have a loose connection somewhere. Did you add the required 4 gauge block to ground point ground when you installed the 3G alternator.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
1990MustangLX50
89
  • Oct 14, 2010
Ive had the 3G alt for a while with no issues and no upgraded ground wire, ill look into that but this issue has recently started, ill dump the codes and hope something turns up, Although my ground cables looks like its OE still, it probably wouldnt hurt to upgrade it.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 15, 2010
  • Oct 15, 2010
Grounds
Grounds are important to any electrical system, and especially to computer controlled engines. In an automobile, the ground is the return path for power to get back to the alternator and battery.
1.) The main power ground is from engine block to battery: it is the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
Any car that has a 3G or high output current alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects. The 3G has a 130 amp capacity, so you wire the power side with 4 gauge wire. It stands to reason that the ground side handles just a much current, so it needs to be 4 gauge too.
The picture shows the common ground point for the battery & extra 3G alternator ground wire as described above in paragraph 2. A screwdriver points to the bolt that is the common ground point.
The battery common ground is a 10 gauge pigtail with the computer ground attached to it.
Picture courtesy timewarped1972
Correct negative battery ground cable.
3.) The computer has its own dedicated power ground that comes off the ground pigtail
on the battery ground wire. Due to it's proximity to the battery, it may become
corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness.
4.) All the sensors have a common separate ground. This includes the TPS, ACT, EGE, BAP, & VSS sensors.
5.) The O2 sensor heaters have their own ground (HEGO ground) coming from the computer. This is different and separate from the O2 sensor ground. It is an orange wire with a ring terminal on it. It is located in the fuel injector wiring harness and comes out under the throttle body. It gets connected to a manifold or bolt on back of the cylinder head.
6.) The TFI module has 2 grounds: one for the foil shield around the wires and another for the module itself. The TFI module ground terminates inside the computer.
7.) The computer takes the shield ground for the TFI module and runs it from pin 20 to the chassis near the computer.
8.) The computer's main power ground (the one that comes from the battery ground wire) uses pins 40 & 60 for all the things it controls internally.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
Extra grounds are like the reserve parachute for a sky diver. If the main one fails, there is always your reserve.
The best plan is to have all the grounds meet at one central spot and connect together there. That eliminates any voltage drops from grounds connected at different places. A voltage drop between the computer ground and the alternator power ground will effectively reduce the voltage available to the computer by the amount of the drop.
1990MustangLX50
89
  • Oct 17, 2010
Any other ideas? Its not a bad ground I have checked them all, they are all good, no codes in ECU
1990MustangLX50
89
  • Oct 20, 2010
Ended up being water in the gas due to the car sitting for a while, couple of tanks of gas later and all is well.
Just my opinion however your statement about requiring a 4 guage ground is not true it is not required 4 guage power wire is, Ive ran a 3g alt for over a year now without issue, nor did PA performance say it was needed.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 21, 2010
  • Oct 21, 2010
Rather that bore you with an explanation of electrical theory and how long I have been fixing electrical & electronic equipment, I will tell you this:
Current is the same on the power feed and return legs of a circuit.
If you have 130 amps going out the power feed (alternator to starter solenoid) you have 130 amps coming back to the alternator through the return ground circuit.
If you still doubt, see Circuit Theory using Kirchoff's Circuit Law
You may have never pulled 130 amps and experienced the voltage drop across an undersized ground wire(s). The voltage drop causes heat and the heat increases the resistance and causes more voltage drop.
Just because PA Performance didn't think of a way to sell you a fancy ground cable does not mean that it isn't needed.
1990MustangLX50
89
  • Oct 21, 2010
ok.
1990MustangLX50
89
  • Oct 21, 2010
When I have some more time I will read that theory. Ive been taught some on electrial systems but that theory was never metioned.
T
Engine Need help figuring out misfire and backfire
  • trystancounts
  • Sep 25, 2025
Fox 5.0 Mustang Tech Sep 26, 2025
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
