  • Digital Self-tuning Forum
stupid 02 sensor ?
  • Thread starter Thread starter j753303
  • Start date Start date Sep 28, 2020
j753303
73
28
28
MASS
Sep 28, 2020
  • Sep 28, 2020
another stupid ms3 question. when i use a wideband on the passenger side for the goldbox can i completely remove the factory 02 sensors and harness then put a plug in the other hole?
93Stang5oh
266
Manchester, Iowa
Sep 29, 2020
  • Sep 29, 2020
You could do that but the MS3 Gold Box has 2 Oxygen Sensor inputs so I'm not sure why you wouldn't go with a sensor on both banks?
j753303
73
28
28
MASS
Sep 29, 2020
  • Sep 29, 2020
i didn't know that was an option. how does that work with the afr gauge? and wiring it up? would the gauge just read 1 but the gold box would use both?
93Stang5oh
266
Manchester, Iowa
Sep 30, 2020
  • Sep 30, 2020
You would need two separate controllers and two separate gauges, one for each o2 sensor. You really don't need the gauge unless you want to compare what the gauge is reading/showing as to what Megasquirt is reading.
j753303
73
28
28
MASS
Sep 30, 2020
  • Sep 30, 2020
do people typically run 2 wide band sensors?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 1, 2020
  • Oct 1, 2020
Turbo guys run 1 as its measured in the downpipe.
2 is not absolutely required but some engines (about 50%) have a .5afr difference between banks and with a second O2 you can trim one side to match the other. The ECU will even do this for you.
j753303
73
28
28
MASS
Oct 1, 2020
  • Oct 1, 2020
i have the aem x series gauge and controller. what do i need to set it up for 2 widebands? it looks like the gauge is the controller? and would the gauge just see 1 bank?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 1, 2020
  • Oct 1, 2020
Unfortunately you would have to have a second wb O2. Controller and all. It has to match the first one you have.
j753303
73
28
28
MASS
Oct 1, 2020
  • Oct 1, 2020
https://www.summitracing.com/parts/inn-3891?rrec=true
what do you think of this? or does 14point7 have something i could put together?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 1, 2020
#10
  • Oct 1, 2020
  • #10
That would work just fine.
You could also just use two spartan2 WB but they wont have a gauge to go with them.
Admin Dude
Jan 4, 1985
43,327
21,512
234
Box behind Walmart
Oct 1, 2020
#11
  • Oct 1, 2020
  • #11
Why could you not use the Spartan as the second and scale it?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 1, 2020
#12
  • Oct 1, 2020
  • #12
The software is hardcoded to only accept one scale for the WB input. This means that all WB controllers need to be the same or scaled the same.
You can monitor any input you want for data logging at any scale but to use them as EGO inputs they must go through the main AFR mapping.
Most units these days can be connected to a laptop via serial connection and using their software you can rescale them so that they all match, then this scale is then input into the MS. The scales have to match even if they are CANBUS connected.
Reactions: Noobz347
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Engine Dreaded 5v reference
  • 89foxstang
  • Jun 24, 2026
89foxstang
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
