Stupid Question
  • Thread starter Thread starter kpack5982
  • Start date Start date Apr 9, 2007
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Apr 9, 2007
  • Apr 9, 2007
I'm replacing the fuel filter and forgot which way it needs to face? It is inline on the line that goes to the engine for fuel right, not the return line?
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Apr 9, 2007
  • Apr 9, 2007
to the engine....is it not a stock one? there is a holster up under there right?...i am sorta confused
kpack5982
Jul 13, 2005
325
Granger, IA
Apr 9, 2007
  • Apr 9, 2007
yeah, there's a holster thingy, but I forgot to mentally note which way the pump was facing, the rounded side which way? I mean the lines, does the rounded end go to the part of the line going to the engine or the part of the line that goes to the fuel tank? Is the filter on the line going to the engine, like fuel has to go through the filter to get to the engine, or does it get filtered on the way back from the engine?
P
PJB
131
Rotterdam, NY
Apr 9, 2007
  • Apr 9, 2007
There should be arrow with the word flow on it.
The arrow needs to point to the front of the car.
ShortThrow50
923
Pa
Apr 9, 2007
  • Apr 9, 2007
lol. it only goes one way into the bracket. Ill pay ya 100 bucks if you can attempt to get it in the wrong way
sunil6784
620
Boston, MA
Apr 9, 2007
  • Apr 9, 2007
The fuel filter filters fuel as it goes from the tank to the engine. There should be an arrow on the filter showing the direction that the fuel should flow.
If its a motorcraft filter. I *THINK* the rounded part goes on the line going to the engine. But follow the arrow to be sure.
kpack5982
Jul 13, 2005
325
Granger, IA
Apr 9, 2007
  • Apr 9, 2007
lol i guess i got it figured out. I couldn't figure out what the hell was wrong with my car and i've reset the idle like 20 times and played with timing and everything and low and behold i replace the fuel filter for 11 bucks and it runs like a raped ape!
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Apr 9, 2007
  • Apr 9, 2007
what were the symptoms?....hesitation?...like a miss? Im having some issues..
4G-KDMP
935
CA
Apr 10, 2007
  • Apr 10, 2007
bingo!!!
kpack5982
Jul 13, 2005
325
Granger, IA
Apr 10, 2007
#10
  • Apr 10, 2007
  • #10
yeah i was getting a crazy hesitation. Thinking about it, the car kinda acted like it was running out of gas ( I might have "accidently" almost ran out of gas before) so I was thinking maybe I'd replace the fuel filter, it has been like 4 oil changes ago too, so it was prolly time. Low and behold it worked!
I guess I should have thought about that. I thought it had something to do with too much air coming into the engine because when I put my 75mm maf on it seemed to hesitate more. But with the stock one it worked a lot better. I mean I went through the whole surging idle checklist aside from the stupid fuel filter and did little to correct the problem.
9
90bluegt
592
#11
  • Apr 10, 2007
  • #11
What tool did you use to get the filter off? I desperatly need to change mine, but not sure the tools to change it with.
4G-KDMP
935
CA
Apr 10, 2007
#12
  • Apr 10, 2007
  • #12
the filter is located on the outside of the tank on the body near where the spare tire sits.
all you'll need to remove the filter is a screw driver to loosen the band that holds in place.
kpack5982
Jul 13, 2005
325
Granger, IA
Apr 10, 2007
#13
  • Apr 10, 2007
  • #13
Yeah, you can just break the white plastic clamps on them with a screwdriver or needlenose pliers. The new filter comes with new clamps.
9
90bluegt
592
#14
  • Apr 11, 2007
  • #14
I got the white plastic clamps off, but the connections look like they are the same as the ones that go to the fuels rails with the injectors.
sunil6784
620
Boston, MA
Apr 11, 2007
#15
  • Apr 11, 2007
  • #15
There's a tool you can pick up at any parts store. Its designed to go into the fitting and release the clips which attach to the line.
personally, I like the small plastic/metal tools (metal is better). THe scissor style stinks.
4G-KDMP
935
CA
Apr 11, 2007
#16
  • Apr 11, 2007
  • #16
there not the same as the ones that hook tio the fuel rail.
i believe there is a o-ring inside that part so there hard to pull off the filter.
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Today at 5:24 PM
Mcmahst
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
