stupid question?
  • Thread starter Thread starter mustanggirrl
  • Start date Start date Dec 12, 2007
mustanggirrl
No matter where I go, it's like everyone's like, "
Dec 12, 2007
26
lacey, nj
Dec 12, 2007
  • Dec 12, 2007
i just got my mustang(1990) maybe like two months ago, and i don't have blinkers.. and my friend told me that there is two spots where there should be a flasher for them. but i can only find the one on like the floor on the driver side & i was told that there is one somewhere else in the car... and if someone could please tell me where it is id greatly appricate it
also, my friend hooked up my cd player into my car & my tach.. i was wondering why my headlights don't work.. could that be a nother reason with the blinker situation? so to make it seem like i have headlights i wedge my cigarette lighter behind the switch to make highbeams.. and it works & i have lights.. but im wondering is this a related problem?
fkurls1
33
Barrington, Il
Dec 12, 2007
  • Dec 12, 2007
Ive seen schematics for this other flasher but have never seen it with my own eyes...its suppose to be up in the dash on the pass side behingd the glove box but I owned a '89 and a '92 and never saw it. The problem it sounds like your having may not be related to the flasher itself. Check the one under the driver's dash and test it to make sure its good. After that I would strongly suggest checking your grounds first. My first Mustang lost its turn signals because of a bad ground in the rear hatch area. good luck!
mustanggirrl
Dec 12, 2007
26
lacey, nj
Dec 12, 2007
  • Dec 12, 2007
thanks. my friend & i looked for the other flasher on the pass side like behind & around the glove box but had no luck. i guess they really did an amazing job hiding this. i bought a new flasher & still had no luck with it. so im like uhhh? and my friend told me to come on here & ask around. i would have never thought to check the grounds near the hatch.. well i didnt even know the car had grounds near the hatch, so yeah ill get that looked at asap. thanks i really appricate the help since i know nothing about this damn carr
riceslayer302
Banned
Oct 3, 2006
CT
Dec 12, 2007
  • Dec 12, 2007
maybe a dumb question but you obviously checked the fuses/relays right?
mustanggirrl
Dec 12, 2007
26
lacey, nj
Dec 12, 2007
  • Dec 12, 2007
yeah, and it wasn't just me who looked at it either... i did it & so did two other people i know. so im like what the hell???? and im not understanding why they don't work or why headlights don't work... and it's rather annoying with the ciggarette lighter holding it in place im scared it's going to fall out and im not going to realize it & get pulled over for no blinkers or headlights =[
riceslayer302
Banned
Oct 3, 2006
CT
Dec 13, 2007
  • Dec 13, 2007
ok... do you have a voltmeter?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 13, 2007
  • Dec 13, 2007
The flasher is not mounted on the front of the fuse panel. The flasher on the front of the fuse panel is a separate one for the hazard lights. It is in one of several places, depending on when your car was made. Some are behind the fuse panel on the back side, others are behind the radio and some are behind the glove box.
Other possible problem sources for the turn signal malfunction are the ignition switch, multifunction switch and the plastic shell that holds the turn signal wiring connector pins.
A word of caution about multifunction switches is in order here. The multifunction switch (high/low beam, wiper, turn signals) are different for different years. 87-98 will work in any 87-89 car. The 90-93 switches only work in 90-93 cars. You can't put an early model switch in a late model car, nor can you put a late model switch in an early car.
Supposedly you can move the pins around to make the switches work in model years that are different from the car the switch came out of. I cannot verify that and haven’t tried it .
corvetteguy
71
  • Dec 13, 2007
My 89 GT had the flasher attached under and
up the steering column.. NOT THE FUSE PANEL
that is the Hazzard.
You have to reach under the column and fee up the shaft
till you reach the metal blinker (sounds sexy)
It is clipped on and has a little
slack to pull it down a little.
Change it and put it back up there.
mustanggirrl
Dec 12, 2007
26
lacey, nj
Dec 13, 2007
  • Dec 13, 2007
so basically im going to have to take appart the steering column (and no i dont have a voltmeter, my friend did & did something to my car & it blew out the wires & stuff so yeah ha.. dont have one), but i guess thats fine because i have a whole differnet one to put in because i dont like not having tilt.. since my seat has like a "gangsta lean" to it... so i should check it out in there.. and i know when i bought the car they said i had to hold my ignition but he "fixed" it so... i hope i can find it and thank you =]
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
