  • Mustang Sound & Shine All
Sub/Amp Question
  • Thread starter Thread starter Thanatos
  • Start date Start date Apr 27, 2004
T
Thanatos
  • Apr 27, 2004
Will this amp be able to push this set of subs and have good quality?
I'm new to this and I have no idea on what is compatible with what. Any help is appreciated, thank you.
P
Phoenix00GT
245
Bay Area, CA
Apr 27, 2004
  • Apr 27, 2004
I wouldn't...you should use a two channel or mono amp...not the four channel that you are showing here
Plus you should get an amp that will match the RMS of the Subs, if you want to push 4x6s with the other two channels and bridge two to push it that's fine, but try your best to push the same RMS with the subs and amp
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
86 gt replaced fuel pump won’t prime / amp drops in key on position
  • 4eye86fox
  • Jan 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 12, 2026
1989 gt both doors wont lock or unlock help.
  • 1989 mustang gt
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 22, 2025
manicmechanic007
