  • SN95 4.6L Mustang Tech
sub frame connectors
  • Thread starter Thread starter Doomedfailure
  • Start date Start date Jul 4, 2011
D
Doomedfailure
58
  • Jul 4, 2011
Alright I have a 1996 mustang GT automatic and I am thinking I need to get some sub frame connectors. I was just wondering which ones you would recommend? And if the welded ones are better than the bolt on? also they look very simple why not just make your own? I mostly want them for jacking and lift reasons.
txredgt
1,343
33
69
Jul 4, 2011
  • Jul 4, 2011
Steeda's or Maximum Motorsports, don't even bother with bolt on ones. How good of a welder are you? That will depend on if you can do them yourself or not but I don't think it would be worth it since they are only 150.
D
Deleted member 38176
Jul 4, 2011
  • Jul 4, 2011
Maximum Motorsports full length weld-ins
D
Doomedfailure
58
  • Jul 4, 2011
well i looked at some kenny brown ones and they were around 350. And as far as welding i can do it but it dont look good, but i work at a machine shop so i could cut the stock and my grandfather is a retired welder so i would take it to him for the welding =). I asked cuz some just look so simple. I figured the bolt ons were worthless. if anyone has some pics of the pience and where the welds go and the specs. how thick the steel is i am sure i could make it but i could always buy just like making things
Whistler98
PA
Jul 4, 2011
  • Jul 4, 2011
I bought the steeda full length ones years ago. For the price they are nice but I have yet to find someone to install them. My buddy is a great welder and welds many of them on but he does it on his post lift and not a drive on lift. He said he puts the posts under the front control arms but I am not sure if this would be a prob or not.
D
Doomedfailure
58
  • Jul 4, 2011
I planed on just jacking the car up and blocking the tires up so it is raised about a foot and just creeping under the car and welding the connectors in.
txredgt
1,343
33
69
Jul 4, 2011
  • Jul 4, 2011
The problem with what ya'll are wanting is if the car is not under a complete load when you do weld them in the suspension will be wrong. You will put more of a load on other areas that shouldn't see as much stress and break stuff. The only way I can see of getting the car under a complete load would be quite a few wooden blocks to get under all 4 wheels and then your car is balancing on blocks about a foot off the ground which doesn't sound like a good idea at all. You need a full load under normal circumstances and you have no clue what level that is if you plan to just jack up a control arm. Do it right for 350 or do it wrong for alot more in repairs and headaches.
D
Doomedfailure
58
  • Jul 4, 2011
I have jacked my car up and put on outward facing ramps on all four tires and worked under it for amonth off and on without any issued. i had stand in all fours incase but i was not worried. I think this would work fine any whether i made it myself or bought one to put in that is how i would install it. just not sure on the gauge of the steel and the points they weld to exactly. but i do like the Kenny brown becuase of the cross and the jack pts. but seems like most people lean towards the MM so might just get that and add on the other stuff myself. but from what i can see on my car it needs it.
LarsD
2,680
119
123
Texas
Jul 4, 2011
  • Jul 4, 2011
+1 to this. I have these on my Cobra and don't regret it for a second.
D
Doomedfailure
58
#10
  • Jul 4, 2011
  • #10
does anyone know if i can use the MM SFC's with the KB extreme matrix braces and the jack rails? i need to get things straightened out because i think who ever had the car before me did not use a lift or jack properly the pinch weld it damaged looks like someone used a lift on it to lift the car!
txredgt
1,343
33
69
Jul 4, 2011
#11
  • Jul 4, 2011
  • #11
Honestly bro if the previous owner damaged the areas where you are going to be welding them to its going to take alot of beating to get them back where they need to be. I contemplated getting the jacking rails to go with my MM but when you can use the MM to jack to there is no reason for them imo. The only reason they would be good is if you have dumbasses who don't know where to put a jack under a car. I would just skip the Kenny Brown addition and stay with the MM connectors, drive your car onto 2x4 blocks if you are lowered and then jack the car where you need to. Heck if you have a few jacks you can even start on the subframes and then go to the regular spots.
I have not experienced it yet, but I was told by the installer that with subframes you can jack at 1 point of the car and lift 3 of the 4 wheels of the ground, I DO know that you can get 3 wheels dang close to coming off it and that isn't even taking it too high.
D
Doomedfailure
58
#12
  • Jul 5, 2011
  • #12
I think I will just order the MM and try them before i go with the jack rails. but like i said those guys with the lifts sometimes mess things up. I looked at SFC from griggs racing, anyone know anything about these? there stuff seems EXPENSIVE.
D
Jul 5, 2011
#13
  • Jul 5, 2011
  • #13
Kenny Brown and Griggs are overpriced IMO. I looked at them as well when researching my SFC's. Their product is no better than MM or STEEDA yet they charge more than double. I can pretty much guarantee that you'll be more than happy with a pair of MM SFC's.
mransr
1,188
36
98
Riverside, SoCal
Jul 5, 2011
#14
  • Jul 5, 2011
  • #14
as long as they are FULL LENGTH, weld in connectors, you can't go too far wrong...they are just peices of steel
D
Doomedfailure
58
#15
  • Jul 5, 2011
  • #15
Ok might need to just start a new thread. Went to get my car aligned after new tie rods. They informed me the toe in the rear is L.23 and R-.21 degrees they said it was because my frame is torqued. Do i have someone try to straighten this out or is it so small it isnt a big deal. also if i get the SFC will they work since the car is torqued a bit.
Stumbaugh
903
Russellville, Ar
Jul 5, 2011
#16
  • Jul 5, 2011
  • #16
This has always been my opinion on subframe connectors.
Sharad
ALWAYS choose the V over the P!!! Wait... what?
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
Jul 6, 2011
#17
  • Jul 6, 2011
  • #17
I agree. I'd look for a good price on a full length set.
southsounder
#18
  • Jul 18, 2011
  • #18
Yep. I had the MM full lengths along with the KB matrix braces and the jacking rails on my 91 LX. Worked great together, although structurally the KB stuff was probably overkill. I admit the jacking rails were handy.
I'll still probably just use the MM full lengths on my new 01.
E
New Member with 91 foxbody
  • EricMac13
  • Jul 22, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 23, 2025
EricMac13
E
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
C
What does this connector go into?
  • charlie1775
  • Jun 22, 2025
SN95 4.6L Mustang Tech Jun 22, 2025
charlie1775
C
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
