Subframe Connector Install Question
  • Thread starter Thread starter splinterddt
  • Start date Start date Nov 24, 2007
splinterddt
201
Florence, CO, U.S.A.
Nov 24, 2007
  • Nov 24, 2007
Finally I quit screwing around and finally going to install subframe connectors. I have a question for all my fellow gear-heads out there. I remember something about jack stand placement when installing the connectors. I've been trying to keep an eye out on the T.V. shows and search on the internet, but I can't find the info. Everywhere I look it just says "place on jack stands." Where do they need to be placed to correct the "sag" while installing the connectors?
snottystang
32
Vancouver, Canada
Nov 24, 2007
  • Nov 24, 2007
I have heard of doing it only using the factory jack points. I have jack stands under my rear frame right at the leaf spring shackles, another set in the middle of the factory jack points and another set placed under the where the lower control arms attach to the frame. I plan to be doing both floor pans and the sub frames as well.
Fast63
717
  • Nov 24, 2007
You need to place the jackstands under the suspension points. So in the front, put them under the control arms in order to preload the suspension, and in the rear put it under the leaf springs at the rearend housing. This is another good time to use the 2x4's under your tires trick because you basically need to install the subframe connectors the way that the car would be sitting normally on the road.
P
palerider94
573
  • Nov 25, 2007
What's the 2 x 4 trick?
68_stanger
131
Petoskey, MI
Nov 25, 2007
  • Nov 25, 2007
maybe I did mine wrong but when I welded mine in I just drove the car up onto 3 2x6's under each wheel gave me plenty of room to get under the car and weld, nothing jacked up full weight on the car's suspention, and they fit just fine.
Fast63
717
  • Nov 25, 2007
Review this thread about the 2x4 trick:
http://forums.stangnet.com/showthread.php?t=727972
68_Stanger, that is exactly how to do it. You can use wheel ramps under all your tires too if that makes you more comfortable. If you have your car on jackstands the wrong way, your subframe connectors will still fit, but when you lower the car back to the ground, there will be all kinds of load on the subframe connectors, but there shouldn't be. They are supposed to keep your car from flexing only. So your car will probably sit higher if you do it wrong because the frame will not want to flex back to where it normally is when the car is sitting on its tires.
I have to mention too, don't use bolt in subframe connectors, always weld them in. Most bolt in kinds you can also just weld on, but don't bother with the bolts.
splinterddt
201
Nov 26, 2007
  • Nov 26, 2007
I heard that over time the cars start to sag in the middle, especially unibody cars. So shouldn't the front jackstands be behind the engine to take the stress out of the middle, and wouldn't the 2x4 trick not help to correct this?
68EFIvert
639
Camas, Washington
Nov 26, 2007
  • Nov 26, 2007
I placed jack stands behind the engine and let the car sit there for a number of days. Then put it back on the ground and welded them in place. There was a difference in the before and after on how the panel fit. The gaps were much closer to equal throught the car. I saw this technique on Muscle Car, the show on Spike TV.
Here is a link for a how to article.
http://www.fly-ford.com/MM0105-How_To_Install_Subframe_Connectors.html
Fast63
717
  • Nov 26, 2007
I don't think it's really a good idea to try and fix that sag, not even the method you did 68EFIvert. You could make things a lot worse because the car will want to go back to the sag again and when it does, you will have a lot of load on your subframe connectors instead of on the suspension, and that is not what they are meant to do. They are meant to keep the car from twisting in corners and hard launches, not fixing sag and holding weight.
68EFIvert
639
Camas, Washington
Nov 26, 2007
#10
  • Nov 26, 2007
  • #10
Isn't installing a monte carlo bar or export brace doing the same thing to correct 40 years of sag? I feel that if it puts it closer to the way the factory designed the car it must do something positive for handling, braking or predictability of the car. I don't know if the way I addressed the problem is the best but the guy on Muscle Car sure seems to know what he is talking about when it come to chassis work. I would rather do that than weld in 40 years of sag.
brianj5600
1,964
Middle TN
Nov 27, 2007
#11
  • Nov 27, 2007
  • #11
Yes he seems to know, but I don't think he knows. Did you see the one where he totally botched the front suspension on his track car. He put the inner UCA mount high than the ball joint. And when he "fixed it" he lowered it, but it seemed to still be high or level at best. Can you say understeer? If you do it his way it will be different, but if you don't measure the chassis you won't know if it is correct before or after. If you don't know where you are or where you are going, you will never know if you got there.
68EFIvert
639
Camas, Washington
Nov 27, 2007
#12
  • Nov 27, 2007
  • #12
You make some good points. I likely would still go the path I did because I am not likely to push the car to the limit and I got the benefit of better aligning body panels. I will post an update if I start having problems with welds or other complications due to additional stress. Thanks for the friendly debate brianj5600. I like to get a little deeper details on opinions.
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
