Subframe connector questions
Ateup
748
Ok, got a 03 GT vert and one of the first mods I want to do is the subframes. What type do you all recommend and what kind of shop do you recommend put them on? (auto repair, body, muffler?) Can I buy them from AM and have the shop put them on? I heard you want to have them use a lift that you drive up on and not a 4 corner frame lift. This makes sense, is it recommended? Thanks in advance guys.:D
I got the MM FLSFC's and they are awesome. I had Street & Strip install ine when I had my front struts, new tires, and alignment done, so I can't tell ya what they charge for just the SFC's. I believe they charge by the hour and not by what kind of job it is though.
Subframe connectors are subframe connectors. They are all just a piece of metal that stiffens your frame up, i have the MM full length ones on my current car but i had the cheap blue oval ones off ebay on my 94 and they worked just fine.
The only real difference you'll find is the full length and standard sizes. I recommend the full lengths...
Talk to some of your local shops... I just got a set put on my car this past Friday for $130 out the door. The shop owner makes them for Mustangs, and fabbed up a set and threw them on mine. Full length, welded in subframe connectors for $130 out the door sounds pretty damn good to me!
