Subframe connectors installation pic.s???
  • Thread starter Thread starter 1991_5.0_vert
  • Start date Start date Sep 22, 2005
1991_5.0_vert
22
Deer Trail, Colorado
Sep 22, 2005
  • Sep 22, 2005
Anyone have pictures of their subframes so that I can see exactly where they go? Has anyone done this at home, You need to keep the car level when welding them in so I guess that means that I'll probably need a shop to do it huh.
At1Maverick69
220
San Leandro, Cali
Sep 22, 2005
  • Sep 22, 2005
well, you dont really need a shop to do it for you, if you have 4 jackstands a welder, you can do it at home, just make sure the suspension is sitting as it would when it's on the ground, I've installed a set of full lenghts and a few of the basic SFC, basically you bolt them to the front seat bolts first, then mark where they meet with the subframes, grind off the paint form the subframes and start welding. I'm having porblems with mine cuz they barely touch the subframe rails and wont sit with the seat bolts, I hope you have better luck!
Henceforward
The Avatar Master
485
  • Sep 22, 2005
You have more to do than just weld them in on a Convertible.
With mine the shop had to grind off the convertible brackets, and then they had room to mount the sub frame connectors.
They welded them in place, and then painted them. They lifted the car on a drive on ramp... takes a while.
1991_5.0_vert
22
Sep 22, 2005
  • Sep 22, 2005
Our local exhaust shop quoted me 100 dollars, does this sound about right for the installation cost for a vert?
The Fox
354
Port Elizabeth
Sep 22, 2005
  • Sep 22, 2005
thats a good price IMO
Henceforward
The Avatar Master
485
  • Sep 22, 2005
Thats a great price, if they do that job right, and properly remove those brackets.
I paid $225 to have mine installed. (Full Length)
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Sep 22, 2005
  • Sep 22, 2005
The price is more like $300.00 in this area (includes parts and labor).
ExplodingGopher
517
The mistake on the lake (Ohio)
Sep 23, 2005
  • Sep 23, 2005
you guys think a 90 amp flux core welder can handle this task?
sheff2720
182
Horsham, PA
Sep 23, 2005
  • Sep 23, 2005
its not something you should do at home unless you have a lift that you drive the car onto.. the suspension has to be loaded when welding them in.. if its not loaded and say one of your jackstands is alittle bit off, well your car is now welded together in that position.. and when you set it back down it will look like one side is sitting higher than the other.. $100 is a great price for the job, just make sure they grind down the surface before they weld onto it.. and if they dont paint it for you, you should hit it with some underbody paint to protect it from rusting
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Sep 23, 2005
#10
  • Sep 23, 2005
  • #10
Austin's Pro Max in Tacoma (2 locations there) did my Global West's for $140 out the door. Everyone else wants about 200-350.
Note to self ... put down the remote and go buy a welder
1991_5.0_vert
22
Sep 23, 2005
#11
  • Sep 23, 2005
  • #11
Wow guys, those are all really high prices, I guess I'll be getting them installed ASAP and see about this HUGE differenece that everyone's been talking about in the verts with subframes. Thanks again guys!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 23, 2005
#12
  • Sep 23, 2005
  • #12
See http://www.oldwestracing.com/index.html?http://www.oldwestracing.com/articles/subconn/subs.htm - lots of pictures and good info
Suspension Bending my frame connectors
  • limp
  • Sep 3, 2025
Fox 5.0 Mustang Tech Sep 4, 2025
limp
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
Ignition Question
  • WantAn88GT
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
WantAn88GT
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
