Subframe Connectors
  • Thread starter Thread starter RajunCajun
  • Start date Start date Feb 21, 2004
RajunCajun
180
  • Feb 21, 2004
Searched quite a few days for all info on here I could find and nowhere Have i seen anything like Im wondering about doing so I decided to post about it.
Im building my own subframes somewhat like this "How-To"
How-To Subframe Connectors
Only reason I do not like there way is I dont get why mount off the side of the Original frame rails where you will only be stressing it on that side.
My design im thinking about would still use 2" x 2" x 3/16" square tubing but would be like the TCP connectors and mating on the end of the front and Angled into the back.
just wondering if anyone has done anything like this or has thoughts on this being bad etc.
bnickel
5,640
lubbock, texas
Feb 22, 2004
  • Feb 22, 2004
personally i would join them together at the ends of the subframes instead of joing them on the sides
10secgoal
2,801
San Diego
Feb 22, 2004
  • Feb 22, 2004
Go with 2x1 1/4 steel tubing, like your original.1/4 is 4/16, a little thicker than 3/16. Yes you want it on the side. That will give it the most strength, not to mention you won't have any ground clearance if you stack them up front. Think of it like popsicle sticks. If you glue (weld) the thin ends together,like you are thinking, you can easliy twist them apart. Now do it side to side. Get the point ? Tha't why it's also (for the most strength) best to cut out the floorboards running to the rearframes. So you can put them side by side in the back, too. I relize many people don't want to do that, but.... Pm me if you want pics of mine.
RajunCajun
180
  • Feb 22, 2004
heres what im talking bout
RogerC62
833
11
38
Dayton, Ohio
Feb 23, 2004
  • Feb 23, 2004
I saw an article a couple of years ago about fabricated 2X3 tube connectors that were fit into the subframe rails from the firewall back to the forward rear leaf mounts. Anyone know what I'm talking about?
12sec67
1,301
San Diego, Ca
Feb 23, 2004
  • Feb 23, 2004
if you can weld that well yu might just want to do what 10secgoal said and then weld you floor pan back together.
if you going to do them like in the pic let me know and i send you a pic of mine. they are very similiar made out of 1 x 2.
M
mustangracer
360
Southern California
Feb 24, 2004
  • Feb 24, 2004
I think that was Mustang Illustrated. I have a copy somewhere.....but I doubt I'll find it in the next year. It is what I did to mine. 2x3 .090 or .120 wall tubing laid into the front framerail and cut into the rear torque box. It's semi-tricky since you have to angle the middle section two ways, and cut through the floor pan and part of the seat riser. I used to have pics somewhere. I'll look for them..
19stang66
689
  • Mar 30, 2006
brought back from the dead...
ok anyways, do any of you have any pictures that i can look at? Or any write ups of how you made and installed them?
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Mar 30, 2006
  • Mar 30, 2006
I haven't done my ragtop yet, but I think I'm going to use a double frame connector. One will go straight front to back outside the subframes and the other will cross from front left to rear right and vise versa on the inside of the subframes. Both will be 1 1/2 X 1/4 square tubing.I was going to incert 2, 1/2 inch pipes threw each of the 4 subframes and weld them in, then use a grade 8 bolt threw the 2 connectors and the subframe. I think the X-frame will make it quite a bit stronger than a pair of laterals.
19stang66
689
#10
  • Mar 30, 2006
  • #10
how would you get at your trans,driveshaft,etc?
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Mar 30, 2006
#11
  • Mar 30, 2006
  • #11
the whole setup bolts on. Here is a quick sketch;
http://www.majicbus.us/worth/subframeS.jpg
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
9
Paint and Body Rust what to do now
  • 97sn95
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 13, 2026
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
