  • SN95 4.6L Mustang Tech
Subframe Install Questions
  • Thread starter Thread starter GTFTW
  • Start date Start date May 19, 2012
G
GTFTW
51
  • May 19, 2012
I had my MM subframe connectors installed today. The shop that I had them installed comes very highly recommended. They've done countless subframe installs on mustangs and are a mustang-specific shop (they know their concerning these cars).
Anyway, I've always heard that the suspension needed to be loaded while the subframes were being installed. These guys used a 2-post lift (only lift they have) to do the install, so the weight was off the wheels. They assured me that it really didn't matter whether or not the suspension was loaded and that it was just a manufacturer recommendation.
Second, for some reason, they completely forgot about the seat rails (which had been sitting on a cart 10 feet away) and were not installed. They assured me that the entire purpose of the seat rails was to add another connection point for the subframes and to secure them to the underbody a little more. They told me that regardless of the rails, they do extra welding along the connectors anyway (which I could tell that they did, they welded the hell out of them) which would compensate for the seat rails.
Anyways, after leaving the shop, the difference was unbelievable. It feels like a completely different car, so Im guessing that there really couldn't have been much more difference with the seat rails and loaded suspension?
3,287
24
69
Broke
May 19, 2012
  • May 19, 2012
I hope you didnt leave without making them do the rails they forgot?
I always heard you wanted the chassis in its normal load bearing state when you weld them on. Heard rumors (maybe BS) about people doing it the other way and having issues.
san~man
O-G
A little grass shack on a big lava rock
May 19, 2012
  • May 19, 2012
The car should be on a drive on lift (i.e. loaded) when installing the rails, check maximum's website.
G
GTFTW
51
  • May 20, 2012
How could they have done the seat rails when the subframes were already welded on?
I know that, thats what I told them. They assured me that it wouldn't make a difference. These guys are the premium domestic muscle/pony car shop in town (epecially late-model Mustangs). In fact, just about every Mustang in town goes to these guys to do subframes. It's hard to believe that there are so many Mustangs (and other cars) running around with incorrectly installed subframe connectors.
Anyone know whether or not having the weight off the wheels will make a noticeble diffrence?
txredgt
1,343
33
69
May 20, 2012
  • May 20, 2012
Have you seen when a car is on a 2 post lift that your suspension travel is at its lowest point? Could it be that they started the install on a drive on lift and then switched over to get a few more spots welded?
Either way the fact they forgot the seat rails should tell you there is a good chance they don't know what they are doing.
Kornnut
1,999
48
108
Tulsa
May 21, 2012
  • May 21, 2012
Instead of being level with the suspension loaded your car chassis was flexed. I have seen some where the doors had trouble shutting or the sub frames not doing their job. The chassis would still flex. I would cut them off and have them redone. Especially since the seat brackets weren't installed. That helps spread the load where the seat bolts go through. Look at some of the older fox cars and how they have tears in that area.
twogts4us
4,188
12
79
Dunedin, FL
May 25, 2012
  • May 25, 2012
I agree
Reactions: txredgt
Clayton302
79
Hurricane Utah
May 26, 2012
  • May 26, 2012
your car HAS to be lifted with the weight on the suspension. are your doors shutting normal? if they are you have the rarest mustang on earth. your car just got welded while it was tweaked. i would take them off and lift the cars from the front a arms and the rear drive axle or a drive on lift. I have a hard time believing they know what there doing. just my opinion. good luck
ntstock93
18
Central New York
May 26, 2012
  • May 26, 2012
My car was done with weight off the suspension. Doors close same as before install.
G
GTFTW
51
#10
  • May 26, 2012
  • #10
The way that they explained it to me is that they place the arms of the lift as close to the wheels/subframes as possible as to simulate the car having the weight on the wheels. I've checked alignment on the doors (door/fender gap and door rear quarter panel gap) and everything looks exactly the same. Both doors open and close flawlessly from what I can see.
These guys do hundreds of mustang subframe installs. They are the mustang destination shop anywhere in the city.
twogts4us
4,188
12
79
Dunedin, FL
May 26, 2012
#11
  • May 26, 2012
  • #11
What city are we talking about?
Clayton302
79
Hurricane Utah
May 27, 2012
#12
  • May 27, 2012
  • #12
what city is this in?
Door glass fastener question
  • limp
  • May 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 25, 2026
limp
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
F
Getting my old autocrosser running again
  • flightops
  • Aug 28, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 28, 2025
