SUBFRAME ?'s
  • Thread starter Thread starter Makdaddymac
  • Start date Start date Jul 20, 2006
M
Makdaddymac
323
orlando
Jul 20, 2006
  • Jul 20, 2006
i want some sfc's the bolt in type and then eventually weld them in. something like these: http://cgi.ebay.com/ebaymotors/86-8...016QQitemZ260010111541QQrdZ1#ebayphotohosting
I was just wondering about the ease of install. Does the exhaust have to be removed.If so should i have to weld them on once there bolted on to make things overall easy.
Will these things bolted on only hold up for a while until i get them welded.
D
DeVus1
400
P-Town, Va.
Jul 20, 2006
  • Jul 20, 2006
First off, I dont trust any subframe connector worth only $35 bucks. Secondly, you will not have to remove the exhaust to weld them in. If you bolt them in, you may have to remove the exhaust as they attach to the seat bolts. When I had my 93 Cobra, I had Steeda subframes installed, and would easily recommend them again.
M
Makdaddymac
323
orlando
Jul 20, 2006
  • Jul 20, 2006
ok i agree with the cost thing..........I do.... i just wanted to know about the installation; so i would have to remove the exhasut no matter what.. so to make things overall easiest i should bolt and weld at the same time....
D
DeVus1
400
P-Town, Va.
Jul 20, 2006
  • Jul 20, 2006
If you do a lot of hard cornering, the bolts will break after awhile if you dont weld them in.
8950HO
658
  • Jul 20, 2006
Forget the bolt in type.Do it once right and get the weld in type.
M
Makdaddymac
323
orlando
Jul 20, 2006
  • Jul 20, 2006
i here the weld in type have fitting problems, were as the bolt in w/ weld are a better fit and there still being welded...
P
philcore3
20+ Year Stangneter
Aug 20, 2004
43
  • Jul 20, 2006
why should it matter how much they cost? Its not a moving part, its a piece of metal. I guess it would depend on how much abuse you plan on giving your frame. Blue oval subframes are on my daily driver and they do their job just fine. Track use, maybe not ??? They are welded by the way, bolted to the seat pan and welded front and back.
D
DeVus1
400
P-Town, Va.
Jul 20, 2006
  • Jul 20, 2006
In the performance world, you get what you pay for.
Venom351R
4,548
41
98
MAINE
Jul 20, 2006
  • Jul 20, 2006
May not be a moving part and just metal but there are all kinds of diffrent metal thinkness and over all quality of the product. Devus is right, you get what you pay for in the mod world.
IMO I would stick w/ either Steeda sub frames or Maximum Motorsports.
carbed87
215
#10
  • Jul 20, 2006
  • #10
i made my own and welded then in myself, but at first i just had them bolted it, well when i finally did weld them in... it was night and day, so yeah, weld in's!
M
Makdaddymac
323
orlando
Jul 21, 2006
#11
  • Jul 21, 2006
  • #11
ok well i guess i'll just weld them in since i wont have to take out the exhaust that way. Making it easier and better..<cant beat that!
smittyb
134
Marysville,wa
Jul 21, 2006
#12
  • Jul 21, 2006
  • #12
I have UPR's and have no problems with them. You shouldn't have to take out the exhaust, even if they bolt to the seat brackets. It would give you more room to work under the car though, if you are doing the welding yourself.
E
eighty8
34
Salt Lake City, UT
Jul 21, 2006
#13
  • Jul 21, 2006
  • #13
I have a set of full length weld-in sub frames made by Global West. Maximum Motorsports also makes a good pair. Buy the full length ones, other articles I have read these advise full length, thats why I bought them. Some manufactures make smaller ones that just just don't make much difference. The ones I have can be tied into a roll cage if needed in the future. Just my .02
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 21, 2006
#14
  • Jul 21, 2006
  • #14
C'mon now...that's a bit close-minded. I work in a factory and one of the maintanence guys is a friend of mine. He's pretty skilled with fabbing up just about anything and he made a press jig that can bend 1-1/4 x 2 inch rectangle tubing the exact same way every time, and he made the bends to follow the chassis of the car. The steel we use to make them is WAY stronger than anything you're going to find on the market, and since it's all scrap steel, it's FREE. I wouldn't call that getting a cheap product just because it's inexpensive, would you?
And before anyone mentions weight...c'mon, it's going into the chassis...subframes are an area where strength and rigidity will always outweigh any kind of weight gains. The sets he makes are as high quality as anything out there and he sells them for 60 a pair and makes them on demand.
I think these companys that cash in with their $100+ sets of subframes are really ripping people off who don't know any better.
I guess i should add, that i'm not saying some guy's $35 subframes ARE good quality, i'm just arguing that not everything quality out there has to be expensive.
89white50
440
central MA
Jul 21, 2006
#15
  • Jul 21, 2006
  • #15
honestly that tubing from blue oval is EXTREMELY strong and thick IMO. why do i know? i have a pair sitting in the shed until i get around to having them welded in. First thing ya gotta do bud is have the ends welded up so they dont rust out fast. but they are very heavy duty.
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Jul 21, 2006
#16
  • Jul 21, 2006
  • #16
any square tube can be used as frame ties I have welded in several sets on mustangs f bodies and other cars. those 35.00 ones are fine.
stihl-066
90
#17
  • Jul 22, 2006
  • #17
I just bought a set of them and am extremely happy with them. For the price they are great. But be sure to weld them in.
LEE93COBRA
1,929
Alabama
Jul 22, 2006
#18
  • Jul 22, 2006
  • #18
my .02.
I see no real advantage to full lengths over standard lengths. I have used Kenny Brown standard lengths SFC's on all my cars. Also installed MM full lengths on a customer's car and saw no advantage over the standards.
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
E
New Member with 91 foxbody
  • EricMac13
  • Jul 22, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 23, 2025
EricMac13
E
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Mid lenght sub frame connectors (straight)
  • Dontknowchit
  • Apr 13, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 14, 2024
bird_dog0347
