I currently have the a stock 5.0 50oz balancer with the motor I am building,
since the rotating assembly is getting rebalanced (changed flywheel, clutch, rod bolts) I thought it would be wise to change the balancer?
I need a 50 oz balancer for an early 3 bolt crank pulley setup. Typically this would be the same balancer you'd put on a 5.0 except it requires a spacer.
The only company I can find is CAT, which I've heard mixed feelings about and some have said their stuff is junk
I don't want to spend $400 on a balancer, even something used will work but eBay has nothing.
If I use a stock 4 bolt balancer it will require me to get a special pulley from March which is $100, so if I can get a balancer for under $200 I can eliminate the need for a new pulley and at the same time have a better balancer.
Any ideas?
Any ideas?
