suggestions for my 5.0
  • Thread starter Thread starter 875.0curt
  • Start date Start date May 27, 2005
875.0curt
  • May 27, 2005
hey i have a question i have aod transmission w/ shift kit, 2400 stall converter, and b&m ripper shifter, 5.0 stock block, gt40 heads port and polish, ford svo 1.6 roller rockers, cobra upper and lower intake with 1" phenolic spacer, 19 lbs injectors, 65mm throttle body, bbk cold air kit, and 73 mm mass air, and plished aluminum underdrive pullies, 3:73 gears, i run a 13.48 at 104 mph with street tires the car doesn't spin. if i leave on a dead stop, or if i am rolling like 2 km/hr, my car will not spin at ALL, why is that, and i bougha bbk fuel pressure regulator today, will that do anything for me, i am not sure if i am loosing power, my car runs a little to rich, just wondering on how to fix that.
whtpny
338
Spokane WA.
May 27, 2005
  • May 27, 2005
Well if you are sure that it is running rich then put on the AFPR and also a gauge and then adjust it down a bit and drive it. You can have it dyno tuned to get the most of it. I would assume that with 3.73s there should be no problem spinning the tires. Heck even my bone stock 2.73 vert will roll em a few feet off the line and mine is a vert. By the way where do you have your timing set at. I hope at least 12 or 14 BTDC. Quite a few people even get to 16 or 18* BTDC.
HISSIN50
34
129
May 27, 2005
  • May 27, 2005
the puter will try and keep the A/F trim stoich. a wideband or tune would be revealing as to richness.
good luck Curt.
875.0curt
  • May 30, 2005
my timing is set at 14, it was set at 18, but would bog down low...
  • dan50
  • Jul 18, 2026
dan50
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
