Summer Operating Temperature
  • Thread starter Thread starter BiminiBlueLX
  • Start date Start date Sep 6, 2010
BiminiBlueLX
37
Tucson, AZ
Sep 6, 2010
  • Sep 6, 2010
Yesterday I changed the thermostat in my '91 5.0 lx from the stock 195* to a 180*. I live in Tucson, AZ and the high got to around 100* give or take and with 30-45mins of run time the car stayed around the R and M of NORMAL. I'm guessing that would be 200*-210* roughly. What my main question is, however, is this the correct operating temperature with those conditions listed? Am i still running too hot, or is it just from the outside temp that's causing it?
From what i heard the 180* t-stat doesn't open until about 200* anyways. So, would this be a normal summer operating temperature here in AZ?
Thanks in advance!
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,114
224
Massachusetts
Sep 6, 2010
  • Sep 6, 2010
Well I am not in arizona, but my car runs 188* on an auto meter mech temp gauge all the time no matter how hot.
Imalso have a 180 stat, so it def opens before 200 as my car only hits 200 if I forget to turn the e fan on and let it idle for a few mins
HISSIN50
34
129
Sep 6, 2010
  • Sep 6, 2010
Not sure on interpolating the stock gauge - it's way too inaccurate to be useful. Get an aftermarket gauge if you can. If not, use an IR thermometer or other means of determining temps.
I'd also recommend a balanced 180* t-stat for the climate.
You will probably find that you run about 100* over ambient temps (when ambient is triple digits).
BiminiBlueLX
37
Tucson, AZ
Sep 7, 2010
  • Sep 7, 2010
Fixed! I ran the car later with the rad cap off, to make sure all the air bubbles had a chance to get out, bleeding it thoroughly. The heater was on full blast for about 15 minutes during this too, since I've seen that helps. I noticed after starting the car that the coolant level was really low, so I filled it up to the rim while the car was on, put the rad cap back on and went for a test drive. She held up perfectly and stayed around 180* the whole drive.
D
1996 gt mustang block temp vs coolant temp
  • Dkuehn
  • May 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 22, 2026
squeak93
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
