sunroof problems
  • Thread starter Thread starter blue87lx
  • Start date Start date Sep 19, 2005
blue87lx
175
  • Sep 19, 2005
i have an 87 lx and i need a new sunroof or moonroof whatever it is mine is cracked. my problem is all the mustang sunroofs ive seen are a different shape than mine. mine looks like a rectangle with rounded corners and the others have a little bit of a different shape and are wider. any ideas?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Sep 19, 2005
  • Sep 19, 2005
Do you have an aftermarket sunroof? Or an OEM?
If you have aftermarket you will probably have a hard time finding replacement parts. You might need to get the next size up sunroof to fix it.
If you have an OEM, then you can probably search eBay or J/Y's to find one.
blue87lx
175
  • Sep 19, 2005
i dont know it was in the car when i bought it. i guess its not oem cause the ones at the shop gt and lx where both different unless ford put a differnt one in my year
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Sep 19, 2005
  • Sep 19, 2005
The way to tell if it's OEM:
On the glass panel there should be two metal tabs (front of glass facing the front of the car) and a bulky release handle that is all black with two chrome release pins
On the roof: The two tabs slide into two yellow plastic receivers. the rubber weather stripping faces up and the metal overlaps the glass section
it's hard to explain, maybe tomorrow I can get some pictures of my Dads car.
87-93 Mustang T-top/Sunroof production numbers
  • Mustang5L5
  • Jan 6, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Mustang5L5
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
