Super Six Motorsports.
2011_Kona_Blue
Do any of our 3.7 owners on here purchased the high performance cams for our 3.7 from Super Six Motorsports. It appears they are the only company that makes performance larger cams for our 3.7 and was wondering if the $ 1,475 per set was worth the power hp and torque gains.
I am just throwing the idea around at keeping my 3.7 completely N/A and was wondering if these performance cams were worth the money for the extra power you get. I also was looking for a much more aggressive louder idle when sitting at a traffic light and you can here those bigger cams rumble. Is this the case with these performance cams for our 3.7?
Will these performance cams really help with torque gains for that low down power or not really. I understand our 3.7 is not a V8 but that doesn't mean the 3.7 can't sound bad ass.
Did you check out fords cams, any bigger cam is going to help our 3.7 with torque, i believe any power adder can be bought thru ford including interals, check it out and let us know--- CHOP
super six is the only shop in the usa that I know of that has custom grinds for our ford v6's, and these are custom regrinds done for them , they are also the only company with pistons for which they have a deal cut with wisco to make them for them only,
I had them build the long block 4.0 for my 07 and can only grade them highly,
as to the 3.7 you will need to also change the springs as the stock ones can not handle the cam's extra lift ,making it a better move to pull the heads and send them to Atlanta GA, have them done properly.
