Supercharged but has CARBON Build up
  • Thread starter Thread starter TOM B
  • Start date Start date Dec 11, 2006
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Dec 11, 2006
  • Dec 11, 2006
I took my blown 347 stroker apart to check it out and found some carbon build up on the pistons and heads.
Am I running to rich, it does burn the eyes a little. The engine runs very good and only a year old and has NO blow by and the oil stays very clean when I change it so the engine is in very good shape, but the carbon build up has me confused. I would like to put NOS on it also this winter and if I have a problem I need to fix it now.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Dec 11, 2006
  • Dec 11, 2006
Definately sounds like it's too rich. Do you have a wideband O2 sensor/guage?
It should be mandatory for forced induction engines.
iskwezm
4,159
20
79
Rowland Heights,California
Dec 11, 2006
  • Dec 11, 2006
shouldnt the fuel injection be adjusting for that????
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Dec 11, 2006
  • Dec 11, 2006
Yes I do have a wideband 02 sensor and a 2 bar MAP sensor. I have the Holley commander TBI injection that all programable from my laptop, maybe I paniced with the blower and ran to much fuel. I would have to get the laptop out but I think I have the A/F ratio at 10.5:1 running the blower. If you guys think that its a fuel related problem then I will clean it up and put it back together then tune it down some.
ISKWEZM, What do you mean adjusting for that, Yes the 02 compensation limit does adjust for what I have the % at, but maybe I didnt do that right, the Holley fuel program is a bit confusing to me and I couldnt find anyone else that set up a blower with it on a ford. What ratio are you running.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 11, 2006
  • Dec 11, 2006
Keep in mind that a 2 Bar MAP sensor is only good for 14.7 psi on the boost gage. I don't think you're huffing more than that, though.
It really depends on how much time you're spending at high vacuum cruise as opposed to high boost. The idle and high vacuum cruise can be tuned up to 14.5 to 15:1 AFR since it is at such low load. Any richer than that and it's really a waste of fuel. If the carbon is dry, it is most likely fuel. 10.5:1 AFR is pretty rich for a mild F/I engine, but I'm not sure just how "mild" of an engine we're talking about.
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Dec 11, 2006
  • Dec 11, 2006
Please see my SIG and maybe that can help
65ShelbyClone
4,675
38
119
Dec 11, 2006
  • Dec 11, 2006
Ok, I was right. I stand by what I said in that case.
F
ForceFed70
4,818
BC Canada
Dec 11, 2006
  • Dec 11, 2006
10.5:1 is too rich. No wonder you see so much carbon buildup.
12.5:1 is good for when on the boost. 12:1 if you want to be extra safe.
iskwezm
4,159
20
79
Dec 12, 2006
  • Dec 12, 2006
I assumed the processor would compensate for a bad A/F, i didnt know it had to programmed top a ball park A/F.................I couldnt tell you my A/F because my cam is so wrong we couldnt even get the A/F to lean out on the dyno, so my engine is comming out this week to make a few changes and get some tuning done.
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Dec 12, 2006
#10
  • Dec 12, 2006
  • #10
Wow bottlefed, 10.5 to rich, maybe im way over kill here, I will clean it up and put back together then tune it.
I hope you guys can help me then with the tune numbers, sometimes the Wideband stuff confuses me.
65ShelbyClone
4,675
38
119
Dec 12, 2006
#11
  • Dec 12, 2006
  • #11
The wideband is pretty easy once you get it all sorted out.
6T6coupe
219
#12
  • Dec 13, 2006
  • #12
Not sure how the Holley Commander works, but the ECU is probably compensating for the AFR to some degree, based on EGO readings, but most ECU's will only do so much. A 25% change would be big. My Megaquirt is only making AFR changes in the 5-8% range.
Try moving the AFR at WOT to something in the order of 11.5:1 and see how that works out. You may actually pick up a lot of power.
65ShelbyClone
4,675
38
119
Dec 13, 2006
#13
  • Dec 13, 2006
  • #13
The ECU's authority to richen/lean the mix should be adjustable in the programming software. 25% is indeed a lot, but there are other safeguards that can be used if the AFR starts going too lean and the ECU doesn't have the authority to fatten it enough.
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
