  • 1994 - 1995 Specific Tech
Supercharger and Timing
  • Thread starter Thread starter tjh566
  • Start date Start date Nov 9, 2006
First Prev 2 of 2
T
tjh566
608
Northern Va
Nov 11, 2006
#21
  • Nov 11, 2006
  • #21
My goal is 6psi, Cheap Hp, And a Neat project to work on, I know its gonna be alot of work, the fab work im getting my dad to help me with, he was a welder/fab for 20 years, and with a little time I think it will go together nicely.
About the crank pulley, I didnt know about the 8-rib and such like I said im new to all this supercharger stuff, What crank pulley do you sugggest and where did you get you pulley for you supercharger at?
JimBowy
330
Downriver, Mi
Nov 11, 2006
#22
  • Nov 11, 2006
  • #22
I'd suggest you do more research before continuing. I'd look for a Vortech crank pulley with the 8-rib s/c pulley (somewhere around 7" diameter). You can find pullies for the M90s all over the web, I'd suggest you go to www.sccoa.com as the supercoupe guys have tons of information.
T
tjh566
608
Northern Va
Nov 11, 2006
#23
  • Nov 11, 2006
  • #23
do you have a 5% pulley or a 10% pulley on it?
JimBowy
330
Downriver, Mi
Nov 11, 2006
#24
  • Nov 11, 2006
  • #24
neither, stop looking at the %'s and consider the actual diameter of the crank and the supercharger pulley.
M90 8-rib Pulley measures 2.43"
Supercharger 8-rib Crank Pulley measures 6.92" (note: this is not the same as the 6-rib accessory crank pulley)
T
tjh566
608
Northern Va
Nov 11, 2006
#25
  • Nov 11, 2006
  • #25
If the formula I found is correct your spinning that thing at 15662.55 RPM with you hit 5500 rpm in your car from what Ive read max safe is 14k rpm?? please correct me if im wrong.
JimBowy
330
Downriver, Mi
Nov 11, 2006
#26
  • Nov 11, 2006
  • #26
sort of, the blowers are rated at 14,000rpm - however the blowers are known to take up to 18,000rpm (again check with sccoa.com)
Eaton engineers will spin these things up all the time, they know what they can take
you planning on staying with 24lbs injectors? even the 3.8L supercoupes had 36lbs
T
tjh566
608
Northern Va
Nov 11, 2006
#27
  • Nov 11, 2006
  • #27
the FMU will help support my fuel needs for now by raising fuel pressure, will upgrade in the future
JimBowy
330
Downriver, Mi
Nov 11, 2006
#28
  • Nov 11, 2006
  • #28
good luck with this project, i'll be surprised if it makes 260rwhp
T
tjh566
608
Northern Va
Nov 11, 2006
#29
  • Nov 11, 2006
  • #29
I probly got close to that now...
First Prev 2 of 2
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
