Supercharger exhaust backfire
  • Thread starter Thread starter KreagerM
  • Start date Start date Feb 1, 2010
K
KreagerM
88
Maryland
Feb 1, 2010
  • Feb 1, 2010
Time to address this issue I'm having with exhaust backfiring.
I'm running 5lbs of boost on my little 289 with a Pro-Flo Efi system. I'm running the stock paxton FMU 12:1. After doing the calculations I should be running a 8:1 FMU. I believe here lies my problem. It's definitely running rich with the 12:1 FMU.
It only backfires at high rpm's (near the rev limiter) as soon as I push the clutch in she lets out a hell of a boom out the exhaust. My buddy behind me said blue flames went shooting out my tail pipes. Sounds way to rich to me. Now this only happens at high rpm, when i press the clutch in.
My timing is right on as per Edelbrock recomendations, my plugs look good. so i'm thinking it's my FMU. Do you all Agree I'm going in the right direction?
Thanks
10secgoal
2,801
San Diego
Feb 1, 2010
  • Feb 1, 2010
Do you have a wideband ? Couldn't tell you on the FMU honestly. If it's that rich a O2 would tell you right away. If you do a WOT pass and check the plugs, it's always easiest with a new set.
Stanger007
2,015
Baton Rouge, LA
Feb 2, 2010
  • Feb 2, 2010
Look at what makes a backfire - if you believe your timing to be correct then you have unburned fuel in the exhaust.
Because this happens at higher RPMs you are likely blowing out the spark or having the spark cut (limiter).
Try gapping the plugs down or raising the limiter temporarily to see if the problem subsides.
Apart from that put a wideband on the car and see where it actually is.
You will find your answer.
Wes
K
KreagerM
88
Maryland
Feb 2, 2010
  • Feb 2, 2010
Yes, The gap. I'll do that as well. I didn't think of that, I know the gap is stock, so that very well could be the problem. Thanks for the advice.
iskwezm
4,159
20
79
Rowland Heights,California
Feb 2, 2010
  • Feb 2, 2010
i used to keep my gap around 30 or less
Stanger007
2,015
Baton Rouge, LA
Feb 2, 2010
  • Feb 2, 2010
Agreed.
Wes
K
KreagerM
88
Maryland
Feb 2, 2010
  • Feb 2, 2010
I definitely give that a try
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
